Oil Lines for Rear Mount setup?
Old 12-14-2008, 09:14 AM
KB240LS1's Avatar
Default Oil Lines for Rear Mount setup?
Im gonna be doing a custom rear mount setup and i need some advice on how i should run the Oil Lines.
Old 12-14-2008, 09:50 AM
extremetoy's Avatar
you might want to ask a question if you want some help
Old 12-14-2008, 10:33 AM
OUTLAWZ RACING's Avatar
Steel braided to the oil pan. Or the back of the valve cover. But I think the oil pan works better. The return should be bigger than the feed and you should have a restrictor in line befor the turbo.
