Warhawk dropped sleeves
Warhawk block, Allpros with 3.3L Whipple running 14lbs.
Engine was down on power & leaking oil.
Pulled one head to find all sleeves had dropped - 2 a bit & 2 alot.
I didn't hang around to see the second head pulled.
So do I just re-deck the block or do the sleeves need fastening somehow to prevent them from dropping further?
I'd obviously like to do this once.
if i were in the market for a big cubic inch i think from what i have heard about the warhawk i would be looking at the lsx block instead.Plus the fact the lsx is half the price of the warhawk block.The only draw back i see with the lsx is the weight compared to the warhawk.
I personally believe the problem was due to poor installation at the time. Warhawk has since corrected the problem. We had a custom sleve puller made just to check before the block was assembled. If you contact World, I am sure they will cover the repair of the block it self.
Worst sleeve drop is 16 thou', most 3 to 5 thou.
Engine was pumping oil onto the exhaust manifold at the worst sleeve I'm guessing because the head gasket was unable to seal on that sleeve.
So who's managed to extract compensation from World?
What does re-decking the block involve?
Again sorry im not good at this.
Yes it was torque plate honed.
I've emailed World asking if there is a permanent solution, but I've yet to get a response.
I'll keep you posted...
