F1-C Corvette 403 CID
guys what should i expect BOOST
for Pulley 4.5 on Stroker 403 With ATI Pulley ( 8 RIB kit )
the car is corvette ,,, the block is Corvette LS2
sounds great bob thanks for the answer
you know Fisal how got the F1-c for the Camaro from you ( jassim got it )
he tried his car
it was Tuned before for T Trim Vortec 15 PSI
his Pulley is 3.9 for the Supercharge
he said the car wasnt that fast ! and the boost was 10 PSI !
i think he has a problem with the Blow Off
anyway ,, i will Post the Dyno for you after we finish
many thanks Boss
he tried his car
many thanks Boss
he tried his car
many thanks Boss
he tried his car
many thanks Boss
Something is not right with Fisal's combination, as it should not even go down as low as 10 psi of boost. I talked to Jassim yesterday, I forgot to ask him about it. Bob
I will give you call tomorrow bob ,
and yes the blow off valve was not right we are going to take it to the dyno today and i will fix it there
good luck for both off you guys on your set ups .
