EPP blower cam?
Old 01-04-2009, 10:13 AM
STAR's Avatar
Default EPP blower cam?
Does the EPP blower cam 232/240 115 have any advance ground in? Where does peak hp occur with a 346 and 402 motor?
Thanks
Old 01-04-2009, 06:57 PM
STAR's Avatar
Bob@EPP???
Old 01-04-2009, 08:01 PM
shawn_c992001's Avatar
to my knowledge no it doesn't
Old 01-04-2009, 08:17 PM
LS1Tech Sponsor
Slowhawk's Avatar
Call EPP tomorrow.
Old 01-05-2009, 09:12 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I am pretty sure it is straight up. Most good FI cams have no advance/retard in them.
Old 01-05-2009, 11:21 AM
kp
kp's Avatar
It has no advance ground it, I installed it straight up in my last two engines.
With a high stall auto and a dynojet its hard to get an accurate peak RPM but I shifted at 7000 and the car was still pulling at 7300rpm through the lights with a 347. Not many hydraulic cammed 347s that ran in the 8s and the the EPP 232/240 is what was in mine when it did.
Old 01-05-2009, 05:28 PM
618HAWK's Avatar
Sorry unable to scan dyno sheet. As for my setup had max Tq of 576@ 4700 Hp 635@6400 This is on a 347. With 10psi on a D1. No telling know with the F1A installed................Thanks KP head unit it is doing great.
Might add very happy with this cam!
Old 01-05-2009, 05:35 PM
Rickys S/C Z28's Avatar
i love my EPP cam! and KP thanks for the D1 IM LOVEING IT!
Old 01-05-2009, 05:45 PM
kp
kp's Avatar
lol, those head units are like my 3rd and 4th kids
I'm glad to see them getting some use.
Old 01-05-2009, 05:53 PM
forcd ind's Avatar
did anyone ck their idle vacume with that cam-i run p/b's and wondered how much vac it had-i had called Bob but he didnt know-thanks
Old 01-05-2009, 05:57 PM
kp
kp's Avatar
I had power brakes on mine and didnt have any issues with the stock brake booster. Its on a 115 LSA so its not that bad, even on a 9.5:1 347, I dont remember what the idle vac was exactly but there were no brake issues at all.
Old 01-05-2009, 06:27 PM
618HAWK's Avatar
Well I don't know if I am treating one well, or beating on one, but it is behaving anyway you look at it. Kid is a screamer though.........lol
did anyone ck their idle vacuum with that cam-i run p/b's and wondered how much vac it had-i had called Bob but he didnt know-thanks
I to have had no problems with brakes, at Idle I will see 12-14Hg, in cruise 6th see 10-12Hg.
Side note MPG 20-23. It has been worse due to a problem with the rh foot.
Old 01-06-2009, 04:39 AM
EPP
EPP's Avatar
Thumbs up
Originally Posted by STAR
Bob@EPP???
The dyno graph above is from an 6 speed '05 CTS-V. LS2/402 with EPP blower camshaft, unported AFR 225 heads, stock LS2 intake and throttle body, ProCharger F-1A at 14.4 psi of boost. Link to car. http://www.exoticperformanceplus.com...Car.php?car=29
The dyno graph is from my powerglide/5000 stall Camaro with a 408 iron block, AFR 225 heads, EPP blower camshaft, Victor Jr intake, N/W 90mm throttle body, ProCharger F-1A at 18.9 psi of boost.
With just warm temperature water in the air to water intercooler, and 17 degrees of timing, we got 834 rwhp. Not bad for an automatic with a high stall converter on slicks!
Link to car. http://www.exoticperformanceplus.com...Car.php?car=12
Thanks everyone for the positive comments, we appreciate them! Bob
Old 01-06-2009, 03:53 PM
LOL!!! mine will be getting beat on soon!!!
Old 01-06-2009, 06:20 PM
OUTLAWZ RACING's Avatar
Dam good cam. I installed it straight up. Im not sure on peak but on my build it kept pulling 6k
Old 01-07-2009, 06:45 PM
EPP
EPP's Avatar
Thanks guys for the positive feedback on our camshaft. Bob
Old 01-07-2009, 08:06 PM
nvmy2000ss's Avatar
Mines done at about 6400, this is a 408 with a d1 could be because of my smaller primaries on my headers. run mine straight up.
Old 01-08-2009, 10:43 PM
LS6 Silverado's Avatar
Hey KP, you said you had great results with the epp cam in your 347ci? Been lookin at that cam for a while now and have not seen to many people using it on the smaller displacments. Hows the street drivability? Im building a 6.0 (365ci) with the new mp t-76 @10psi mostly but will push more on track days. Think this cam would work well with my setup? Dont have ported heads, just fresh 317's with patriot duals. Do you think it would work and be streetable? Thanks!
Old 01-08-2009, 11:23 PM
kp
kp's Avatar
I used the same cam in my 365, its very streetable since its on a wide LSA, at least is was for me. Its no doubt a large cam, especially if you drop the compression a lot, I was at 9.5:1. Going to need a good tune too..
As far as for a turbo I cant say, I'm not turbo cam expert and have no plans of becoming one
Old 01-09-2009, 05:00 AM
EPP
EPP's Avatar
Our cam worked (and still is) very well in this 346 with twin turbos, with very good road manners.
http://www.exoticperformanceplus.com...Car.php?car=26
Here is a video of it. http://video.google.com/url?docid=30...HCAO9kkY_gce6w Bob
Quick Reply: EPP blower cam?
