What is needed to rework my nitrous motor for FI?
Old 01-08-2009, 09:12 PM
Fast GTO's Avatar
Default What is needed to rework my nitrous motor for FI?
This is me just doing some thinking/research and by no means implies this is happening, need to do mini tubs first. Headed back to Iraq again but this time as a combat advisor and need to start a new project (its an expensive tradition each time I leave on a deployment).
Considering a D1 or F1A Procharger or MP 122 (leaning towards the Procharger as I don't need a lot of help down low with this motor). I know I'm going to need to get my compression down and tighten the tolerances on my piston rings but not sure what else nor how much of a pain it would be (i.e. do I need completely different pistons because of the -2cc dish?). Here are the details on the current motor...let me know what you all think needs changed.
- Aluminum 6.2L L92 Block
- CompStar Crankshaft 4340 Forged LS1 Crankshaft -Small Jounral
Small Jounral -2.000" journal -4.000" stroke
- Diamond LS1 4.000" 4.00" stroke 6.125 rod,-2cc dish, uses
ring 09064000
- CompStar 6.125" H beam connecting rods withARP2000 hardware-2.000" journal
- ET Performance LS1 CNC 245cc Runner
4.00" chamber bore
62cc combustion chamber
Patriot Extreme springs .660 lift
- Fel Pro permatorque MLS 4.100 bore .053" thickness
- 11.6 : 1 compression
- 91-93 OCTANE Build
- 30# Injectors
- ARP Studs
- Clevite Bearings
- JP Performance Double Row Timing Chain
- SLP Heavy Duty Oil Pump
- Kooks LT's no cats
- 3" SW Exhaust
- Ported FAST 90
- 90mm NW TB
Piston ring gaps:
Top ring .032"
2nd ring .036"
Old 01-09-2009, 12:32 AM
tim99ws6's Avatar
Change heads to drop compression, and add a blower cam from the sponsor of your choice. You don't need to spend major money on the heads, rather aim to get the compression at 9.5:1 or lower.
You are going to need a better fuel system as well. At the least, you'll need to upgrade injectors, but i would also upgrade the fuel pump if you haven't already. The fast 90/90 will work fine.
Old 01-09-2009, 07:21 AM
Shawn @ VA Speed's Avatar
i wouldnt change heads-just change pistons to lower compression,and get the right cam
Old 01-09-2009, 08:16 AM
Fast GTO's Avatar
Thanks, that is what I was trying to figure out, whether I needed to change heads or pistons or both.
ETP 245's seem to be perfect for an F1A and new pistons can lower my compression as desired.
Fuel system is a given as I've been running a stand alone nitrous dave fuel system with race gas for the nitrous I was running. I figure selling the current pistons and nitrous system would make up for the money I would need to get the new ones.
As far as CR, I am being told 10.8 is a good CR to shoot for on a F1A while an MP 122 application would have a higher CR.
Old 01-09-2009, 08:57 AM
tim99ws6's Avatar
True,
i guess my thoughts were change heads as it's the simple solution, but you have a great set of heads. So yea, in your motor, I'd change pistons.
Old 01-09-2009, 02:44 PM
Fast GTO's Avatar
Which pistons would I need to get the CR down from 11.6?
Old 01-09-2009, 03:04 PM
BLNLS1/RX7's Avatar
Make sure you speed the extra money for a stand alone fuel cell for the nitrous.Harris Speed Works makes a nice unit.
Old 01-09-2009, 03:42 PM
Fast GTO's Avatar
For clarification, I'm already running nitrous. I'm talking about removing the nitrous for a Procharger or TT setup and rebuilding the motor for a lower CR.
Quick Reply: What is needed to rework my nitrous motor for FI?
