D1sc impeller damage.
Old 01-18-2009, 06:19 PM
BigBenz's Avatar
Default D1sc impeller damage.
Ok so my filter poped off. I removed the SC and the impeller is chiped and damage. Any one know how much this is going to cost to have fixed?
Old 01-18-2009, 06:27 PM
EPP
EPP's Avatar
Not sure. It has been a while since I've had one that was damaged and it is going to depend on how extensive the damage is. Give ProCharger a call in the morning at 913 338-2886. Bob
Old 01-18-2009, 06:33 PM
BigBenz's Avatar
not even a ball park? Over under 300 bucks. and are they quick or wil it take 60 days to get my SC back.
Old 01-18-2009, 06:42 PM
EPP
EPP's Avatar
I'd say $700.00 as a guess and only a guess, and they are pretty quick these days. Bob
Old 01-18-2009, 07:45 PM
HS-Y2kFormula's Avatar
I was charged $1100 to repair that exact same damage. That does not include any shipping costs, as the shop that works on my car is located near ProCharger. They just drove it over. Procharger had to completely tear apart the supercharger to make sure there were no fragments of metal still left in the supercharger. Turn around was within a week.
That really sucked, especially on a new supercharger with less than 500 miles..........
Old 01-18-2009, 07:48 PM
'Trust''s Avatar
That sucks man, if it is still under warranty you could try to get it fixed that way, but they may claim that it isn't a manufacturing issue (probably right), good luck!
Bob, are you guys open tomorrow?
Old 01-18-2009, 07:57 PM
EPP
EPP's Avatar
Yes we are. Thanks. Bob
Old 01-18-2009, 08:04 PM
'Trust''s Avatar
Awesome!
Old 01-18-2009, 08:07 PM
kcmags's Avatar
I feel your pain...I have one there now..same deal. It's going to be a nice mantle piece.
Old 01-18-2009, 09:25 PM
BigBenz's Avatar
So i talked to my buddie that had the same SC on his car for 5 years with mild impeller damage. His car drives fine and makes 15lbs boost. My impeller has damage on 2 small fin blades. The rest of the impeller looks perfect. Looks like a small rock hit it. Im not going to let procharger run a scam on me and charge me 1100 bucks for a impeller. Im just going to run it untill it dies. im only run 8lbs of boost. Illl buy a new f1a from bob when this SC is dead.
heres a pic
You can see the small chip and the other damage. Its nothing major. Im sure procharger would take 1100 bucks and tell me its gonna kill my dog if i dont get it fixed. i was still making 8 lbs of boost just 2 days ago and the car was driving fine.
Old 01-18-2009, 10:33 PM
kp
kp's Avatar
I have seen people sell blowers with more damage than that and cal it 'mint' lol.
Take a dremel with a fine stone and clean up the edges around the chipped part so it doesnt start cracking and run it. I doubt you will see any difference.
The impeller is probably the most expensive part to make on the blower, after they put a new one on they have to make sure the clearance to the housing is OK plus I'm sure they disassemble it and check everything plus put new seals in. I'm not defending 1100.00 to do it, thats more than I sold my last complete D1SC for, but unfortunately you have little choice in places to fix it..
Old 01-18-2009, 10:46 PM
'Trust''s Avatar
I don't see how such a small chip would have any affect on boost, perhaps balancing, but the impeller is pretty light so it may not do much? If it were me, I would probably leave it rather than spend the $1100 to fix it, unless it gets worse.
Old 01-18-2009, 10:50 PM
Grr
Grr's Avatar
agreed, i just get a small file or flap wheel on a dremel and make it smooth, it wont hurt anything
Old 01-19-2009, 02:36 AM
That's what she said...
TheBlurLS1's Avatar
Smooth the chip out, and if you're concerned about balance, make the small chip on the opposite blade look exactly the same lol.
Old 01-19-2009, 04:18 AM
EPP
EPP's Avatar
I agree, that is not bad at all. Clean it up as kp suggested and you should be just fine. Bob
Old 01-19-2009, 10:27 PM
nuclearxp's Avatar
I have a silly question. Would it make sense to perhaps take a small amount of metal off the fin directly across from the damaged fins? I would think if you took a minimal amount off the entire fin it really shouldn't kill the impeller performance.
The only reason I ask is because as people mentioned - the impellers are light, but even a slight weight imbalance on a piece turning thousands of rpm has GOT to eventually wear down the bearings. I just figured maybe taking a touch of metal off the opposite side would give the impeller slightly better balance and make it last longer.
Old 01-20-2009, 09:24 AM
Dumb Ass Vette Moderator
ls1290's Avatar
All though this sounds funny, I would definitely think about doing it. Remember that the impeller spins up to 68000 RPMs!
Old 01-20-2009, 02:18 PM
TheBlurLS1's Avatar
I was being serious, but wanted some backup before I admitted it.
Old 01-20-2009, 09:03 PM
kp
kp's Avatar
You are likely to do more harm by trying to balance it by eye them just knocking the high spots off and leaving it be. They arent that light, there is a good amount of material on the back side.
Old 01-21-2009, 12:04 AM
LS1W's Avatar
Default damage
i agree with kp
if youre not going to fix it / just smooth out the rough edges and run it. ive done this on the drag cars and they work out fine ( though its only for the remainder of the event ) - a daily driver is going to see alot more heat/time and will fail alot sooner and with much more damage that that intake wheel.
DO NOT try to balance this yourself you WILL do more harm than good.
i would however try an determine what entered the impeller as that type of damage in the center of the wheel is ONLY CAUSED BY FOREIGN DEBRIS.
SOMETHING got in there.
Quick Reply: D1sc impeller damage.
