New Dyno Numbers: 700rwhp+ LS1 Stock Bottom A&A Vortech V2 S-Trim System
Old 01-19-2009, 10:14 PM
NemesisC5's Avatar
Default New Dyno Numbers: 700rwhp+ LS1 Stock Bottom A&A Vortech V2 S-Trim System
For me it has been a long term goal finally realized; “do more with less”. Starting out with premium parts and continuing to add what I considered to be the best components, my combination continued to build power without adding significant boost. While being concerned of blowing up my stock bottom, I felt the V2 S-Trim would run out of steam about the same time or hopefully before Kaboom. This weekend Advanced Racing Dynamics in Houston installed a Dallas Performance “Big Mouth Air Filter” and custom 4” inlet pipe along with a new custom tune and we hit 708rwhp & 640rwtq @ 11.4psi. These results are, what I believe may be the highest recorded from a Vortech V2 S-Trim on any car. My previous dyno tune on December 27th yielded 693/639 @10.4psi. The new air filter setup allowed the blower to breathe better & in doing so leaned it out a little, so Owen dialed in a little more fuel in two successive runs and we called it a day. After the addition of the DP “BMAF” a new top shroud needed to be fabbed to clear the filter. Kerry, whom I consider to be a very good technician and fabricator, painstakingly & meticulously worked his craft and the results were indeed very functional & clean looking.
I want to thank Owen, Jay and Kerry for their outstanding work and superior customer service. Jay, the shop manager at A.R.D. stayed past 7pm Saturday finishing up the finer details. I also bring my 02 C5Z roadcourse track car to A.R.D. for all my work.
In addition I want to thank Taylor @ Dallas Performance for getting the custom aluminum 4” intake pipe with “BMAF” fabbed and delivered to me in record time. This component added 1psi and 15rwhp, definitely making the difference I needed crossing the 700rwhp threshold. I’m certain on larger builds this component would make an even larger increase.
Lastly, I want to thank Andy at A&A Corvette for designing a superior performing supercharger system. In the near future I plan on installing his newest intercooler for taking the power up another notch.
http://www.youtube.com/watch?v=CtSD240Kd7k
http://www.youtube.com/watch?v=TqRtdaMFM3c
http://www.youtube.com/watch?v=wu6CM6a3bx8
http://www.youtube.com/watch?v=d0c_J0GYE3g
Old 01-19-2009, 10:55 PM
LS1Tech Sponsor
Slowhawk's Avatar
Very nice.Should bring your car up here since it's 0 degree's out.Will dyno 750+rwhp.
Old 01-19-2009, 11:23 PM
NemesisC5's Avatar
Wish I could Bro, I hear that Owen's dyno is actually over 20rwhp stingy at my level...that comment comes from a friend that dynoed back to back on another local dyno. Although I would rather run a stingy roller than a loose one, makes the #'s feel well deserved.
Old 01-20-2009, 06:18 AM
LS1Tech Sponsor
hellbents10's Avatar
Nice numbers, clean setup!
Old 01-20-2009, 11:08 AM
ss1
ss1's Avatar
Nice numbers, especially with what most would call "small" heads and cam. Looks like it has some pretty good midrange, not just peak power.
Old 01-20-2009, 11:24 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Little lean up top no?
Almost 13:1 at 5.5K....
Old 01-20-2009, 11:33 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I think you need new glasses I see it as slightly more 12:1 at 5500.
Old 01-20-2009, 11:51 AM
LS1Tech Sponsor
No, pretty sure I see fine...
The dotted line is 12:1 and the A/F clearly goes above that at 5500 and continues to out past 6500.
That is a bit leaner than I like to see 700 rwhp FI applications, that all....
Old 01-20-2009, 12:08 PM
ss1
ss1's Avatar
The black dotted line is 12:1 and the red dashed line is 13:1. It looks to be just over 12:1 to me also...
Old 01-20-2009, 12:31 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
12.1 is a little lean in my opinion, with methanol or not
Old 01-20-2009, 01:31 PM
'Trust''s Avatar
The dashed line is 13.1:1, it looks to be just about 12.5:1 to me.
Old 01-20-2009, 03:52 PM
blacksi's Avatar
Nice numbers. It looks to be a hair over 12:1 I would also prefer a hair under 12:1 instead of over.
Do you have any idea what kind of timing they are throwing at it?
Old 01-20-2009, 07:20 PM
Mr.Big's Avatar
VERY nice!!!!!!!!!!!
Old 01-20-2009, 08:17 PM
BlackNiteWS6's Avatar
Very nice power!! I'm shocked the bottom end is holding up...man thoseAFR's kick
butt...congrats.
Old 01-20-2009, 08:27 PM
NemesisC5's Avatar
Thanks
Thanks, I believe it is a pretty well matched setup
Definetely closer to 12.3:1 from previous pulls it's showed that it likes a little more fuel so we'll throw some in a touch.
21*
Thanks Mr. Big
Old 01-20-2009, 08:56 PM
9t8z28's Avatar
In the title of your thread "New Dyno Numbers: 700rwhp+ LS1 Stock Bottom A&A Vortech V2 S-Trim System", what do you mean by LS1 stock bottom? And which vette made this power?
Old 01-20-2009, 09:26 PM
NemesisC5's Avatar
My 1999 Coupe still has the factory short block...purchased it new 8-8-98 and it has 21k miles now
Old 01-20-2009, 09:27 PM
9t8z28's Avatar
Damn! How much longer do you think that is gonna last?
Old 01-20-2009, 09:30 PM
NemesisC5's Avatar
Don't know.....but I'll post up when I build a forged motor.
Old 01-20-2009, 09:43 PM
I usually only see YSi Vortech blowers make that much power, not the S-trim. Especially
at much a low boost level. Looks like a very nice match of parts.
Quick Reply: New Dyno Numbers: 700rwhp+ LS1 Stock Bottom A&A Vortech V2 S-Trim System
