my LQ4/4L80E tc78 build
Old 01-19-2009, 10:56 PM
eviltwin_1987's Avatar
Default my LQ4/4L80E tc78 build
well im at the point where i think my build can go into this section. This was all done in my garage by me.
Build info
91 Syclone #1060 Started build on Nov 9, 2008
build thread https://ls1tech.com/forums/conver...c78-build.html
Motor-
2001 LQ4 80,000 miles
ARP rod bolts
LS6 cam
918 springs
60lb injectors
Tranny-
2004 4WD 4L80e
Stock Convertor
Transgo HD2
T-Case-
Stock Syclone t-case
32 spline input shaft
Turbo setup-
Tc78
JGS 40mm wastegate
JGS 56mm BOV
Ebay intercooler 31x12x3
Custom made headerrs, crossover, downpipe
it will be speed density tune at 9psi
here are some pics
Old 01-19-2009, 10:58 PM
video of the first run
Old 01-19-2009, 11:00 PM
Old 01-19-2009, 11:02 PM
here is the stock modded oil pan
the goal for the truck is to drive to the track, run 10's on street tires, and drive home. Dont think i will hit it with a stock convertor but a new one will be put in around summer time.
Old 01-19-2009, 11:38 PM
red_ryderSS's Avatar
That's badass, should be tons of fun. Keep us updated with new vids.
Old 01-20-2009, 12:07 AM
i will. i just got the turbo in the mail today so i still have stuff to do. have to finish the downpipe, turbo to intercooler, hook up oil lines, some vac lines, and hopefully get it tuned by the end of the week or next week. it will be tuned on an AWD dyno.
Old 01-20-2009, 11:02 AM
killerinparadise's Avatar
Build looks good, in for updates, I'm currently piecing together a lq4/tc78/Auto build as well. Should be able to start work on it in a few weeks. Hope you have good results.
Old 01-20-2009, 11:07 AM
mg98ta's Avatar
Nice build. Complements on the header work. They look great. What kinda pipe did u use. Aluminumized, steel, or SS?
Old 01-20-2009, 12:04 PM
Headers consist of gm flanges, 1 3/4 16g mild steel tubing, and cut up hooker collectors. Drivers side took about 3 hrs to cut an tack together, pass. side took around 6 hrs
Old 01-20-2009, 10:19 PM
finished the dp
when i get it tuned should i start with a 7psi spring or go straight for the 9psi spring
Old 01-20-2009, 10:24 PM
TripleWhite96's Avatar
I'd say 7..i'll be tuning mine with a 7lb spring on the gate with the TC78 on Friday, i'll let you know how it goes
Old 01-21-2009, 01:09 PM
Johnv's Avatar
Go straight to 9psi spring or you will be retuning when you decide you need a little more, or leave the 7 psi spring and get a boostcontroller.
Old 01-21-2009, 11:28 PM
got the wastegate on today. started to make the turbo to intercooler pipe too. have some parts coming in the mail tomorrow to finish the job. Also have an appointment on Friday to get it tuned. If everything works it will be seeing the track on Saturday.
Old 01-21-2009, 11:40 PM
SPRAYED 01's Avatar
What size is your turbo outlet to the cold side piping. Mine is 2.5 on my tc78,just curious.
Alex
Old 01-21-2009, 11:51 PM
2.5 on mine
Old 01-22-2009, 09:55 PM
its on the trailer and ready for a tune. hopefully the weather isnt too bad
Old 01-22-2009, 11:58 PM
LilJayV10's Avatar
finished the dp
Thing's you never want to hear the woman in your life say...
You are a fabricatin' fool! The build is awesome. Don't you have another thread about it?(nevermind I just saw the link) I was thinking you were waiting on parts or something a week or so ago.
Old 01-23-2009, 12:09 AM
ya i was waiting on the turbo. ordered 12/10 received on 01/19. all in all it took 2 months 2 weeks for the build but i had a 2 week vacation in the middle. So 2 months
Old 01-23-2009, 11:09 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yeah..that sucked. Wouldn't have taken so long, but Turbonetics was closed from 12/14 through 1/5.....so their came the big delay. Glad to see you have it running....looks awesome.
Old 01-23-2009, 12:36 PM
thanks. i cant wait to drive this thing
Quick Reply: my LQ4/4L80E tc78 build
