cruise control question
new to the ls scene but just finishing up a turbo install on my 2000 camaro. the air cleaner and intercooler to manifold tube go through the area in the driver side fender where the cruise control is mounted. it would be so much easier to delete the cruise control box instead of relocating. does anyone know if the box only handles the cruise control function or does it interface with other aspects of engine/electronic management?
thanks in advance,
eddie
thanks in advance,
eddie
thanks in advance,
eddie
thanks in advance,
eddie
all i had done was take the bracket and set it on the work bench and tapped the bent part of the bracket straight. I then had rebolted it in place and now it tucks the Cruise module under the frame rail. doing this allows more room to run your pipes since the module is now placed under the rail and out of the way
if referring to passengerside its the vaccum hold canister that is for heater controls. some have said its needed but im not sure if im going to relocate it for mine or just elinimate it
