Wideband not working
I asked in the tuning and diagnostics section with not 1 response. Its an AEM UEGO. I have the power wire for it and my electric fuel press gauge T-ed into the 10 amp ignition wire in the fuse box by the steering wheel. The fuel press. gauge works, but the wide isn't even flashing on for a sec. I don't have the sensor in the exhaust. Does it need a signal from the sensor to display anything? I thought that it would at least show zero. I went back N/A and never used it, but I do want to make sure that it does work before I sell it.
Thanks
Nick
Thanks
Nick
Does your wideband, come with a little red button and light like the Innovatives? Mine does and i have yet to install it, so i just wanted to see if that would cause a problem or if that thing is even needed.
-Joel
-Joel
I'll pull the a-piller aprt first tomarrow and check the connectors on the back of it. Hopefully they just came loose when I was feeding it through the dash.
Thanks guys.
