Ideal Procharger Exhaust
Not too loud but wanting to flow well can be a tough call. My exhaust can be seen in the picture below, it flows decent but it isn't what I would call quiet. The Magnaflow cat back is a good all around exhaust system that flows well and should clear for you. Bob
free flowing and not loud isnt gonna leave ya too many options. you must sacrifice one for the other in most cases.
I don't need it quiet.... but it is way to loud for the street right now with no cats and one moroso spiral flow......at idle its fine.....but cruising around at 2k you need to almost shout to talk to passenger......not to mention from y-pipe back is not mandrel bent (main reason I want to change it)
Get long tubes for sure. I'd suggest getting a high flow y-pipe such as the ARH or a modified one with a Flowmaster merge. I've got a custom y-pipe with a flowmater merge. Behind that look into a dynomax bullet in the I-pipe. They are 3" straight through but will help with the loudness. Then follow it all up with a Magnaflow muffler, not to loud and have a great sound.
A lot of people have made good horsepower with the Magnaflow exhaust system, it would be the one I'd recommend. Bob
ready to start buying parts.....but I am on a limited budget....around a grand but can go slightly over
I was thinking about the texas speed 1 7/8" headers w/ ory and then some cat-back system.....maybe even a cut-out
oh and I am keeping the CME
any other advice? I really like the ARH but with the economy like it is, I'm not spending that much right now
Eldebrock LT 1 3/4 stepped to 1 7/8 to a race merge collector w 3 1/2 outlet, about $440, Y pipe is $100, add the Flowmaster 2 into 1 merge, and you got a nice setup, for cheap. If cheap wasn't a concern, I'd for sure go with the ARH. From what I have searched, I dont think you'll see much, if any difference between the Eldebrock, and the higher priced brands. JMO
