Truck manifolds and steering?
Doing my Turbo LS1 swap in my 94 camaro and just put my truck manifolds on facing forward and now my steering linkage from the colomn wont fit... I still have my 94 power steering rack on a tubular k-member. Do I need to go to LS1 rack??
Thanks
Thanks
The problem is I have a 94 camaro with 94 rack and ls1 tubular k-member... I had the manifolds on facing rearward at first and everything fit perfect well I got enough money to do the turbo now so I went ahead and flipped them from side to side facing them forward and now the linkage from the column to the rack hits the manifold dead on. The main thing that hits is the rag joint. Any ideas?
I ran into this same problem because I tried using an older rack on my ls1 car. The angle is not the same and causes clearance problems. Switching to an ls1 rack will do the trick for you.
