Stock Bottom & Boost - Reliability List
Old 06-02-2009, 01:06 AM
  #81
tomz28's Avatar
APS twins
installed at 101k now at 111K about 16 passes at the track
10 to 12 psi
has not broke yet but it does have ARP rod bolts, 317 heads, and 04 ZO6 cam
dyna pak it made 694rwhp but it reads high
dyno dyamcis it makes 625rwhp
Old 06-02-2009, 09:38 PM
  #82
dudeman's Avatar
Originally Posted by mcmillion
TURBO, T-76, 9-12 PSI, 600 RWHP, 105k, now 115k, Nothing Broke
*pro-tuned, 91 oct, 6.0 heads
what cam are you running?
Old 06-02-2009, 09:46 PM
  #83
maxgee's Avatar
Originally Posted by tomz28
APS twins
10 to 12 psi
noice!!!
i dynoed mine at 8psi and made over 5oorwhp on 93oct 16degrees total timing, but now e85 at 12psi, 18 degrees timing, no dyno yet with this set up, but i ran down not one but two procharged vettes, one c5 and the other c6...they claimed 600rwhp.
Old 06-03-2009, 12:47 AM
  #84
tomz28's Avatar
Originally Posted by maxgee
noice!!!
lets us know about the E85 dyno numbers
it sounds cool
Old 06-03-2009, 05:31 PM
  #85
martinls1's Avatar
I dont see any of the magnacharger kits on the list?
Got the MP112 kit (LM Speed) on my stock bottom end and stock heads. Only thing I have is LT headers and TR224 cam.
Got it dynoed at 495hp 464tq
7.5 lbs.
79,100 miles on car when I installed the supercharger
got to about 81,000 miles on it when I bent cyl. #8 connecting rod
EDIT: rod bent due to water leaking into cylinder
Old 06-03-2009, 08:00 PM
  #86
maxgee's Avatar
7.5 lbs.
got to about 81,000 miles on it when I bent cyl. #7 connecting rod
wow, sorry to hear that. curious, did your piston suffer damage? to bend a rod and piston still good, specially stock, indicates some water got in the cylinder.
who did your tune?
Old 06-03-2009, 08:19 PM
  #87
joblo1978's Avatar
- Type of Forced Induction- intercooled MP112 Magnusson Supercharger, Lingenfelter GT2-3 camshaft, stock bottom end, patriot golds, titanium pushrods, ls2 chain, ported oil pump, other bolt-ons
- Boost Amount / RWHP- 6.5 #'s, 518/526 on a safe tune 12.8/1 AF
- Miles on the car when FI installed, about 65,000
- Miles ran since FI has been on the car, I dunno, maybe 1,000, sits in the garage usually but when it goes out, it's ran hard. Haven't had it long
- IF you broke the motor, list what was broken, nothing broken yet, run's really strong, don't think my setup could be blown as a result of boost.
Old 06-03-2009, 08:20 PM
  #88
martinls1's Avatar
who did your tune?
No damage was done to the piston. Car has been garage kept and the car was not driven in the rain the last few times when the knocking noise began. Dont know where the water would have came from.......then there is the intercooler. But I checked the intercooler for leaks and it doesnt appear to be.........so then I just assume that it is from to much power??
And Masport did the tune..........
Old 06-03-2009, 08:56 PM
  #89
maxgee's Avatar
rods bending alone, usually is not from power, but from trying to compress water.
have you pulled the heads off?
Old 06-15-2009, 02:03 AM
  #90
Pewter_LS1's Avatar
- D1SC
- 7-8 psi / 590 rwhp/500 rwtq
- Miles on the car when FI installed - 39,500
- Miles ran since FI has been on the car - 11000
- Motor is Fine.
The following users liked this post:
WS6113 (01-31-2020)
Old 06-18-2009, 12:07 AM
  #91
Spectre86's Avatar
wow its nice to see some of the high mile cars running with no problems
Old 07-16-2009, 12:14 PM
  #92
tirefryin_s10's Avatar
Turbo(Twin T70,truck manifold kit)
installed on freshened up 6.0 with arp rod bolts, not sure on mileage
Made 706/626 on 14 psi/15.5 degrees of timing Through a Th400 with 3800 stall.
Track times coming soon.
Old 07-17-2009, 12:40 PM
  #93
martinls1's Avatar
Maxgee, you are absolutely right! Just found that out the hard way! My intercooler under the maggie was leaking. Thats why my cyl. 8 rod bent! Just installed my new freshly built forged bottom end this past weekend and the same thing almost happened on my new motor. But I think I caught it in time and doesnt appear to have hurt the motor. Got to do a good compression test to know for sure. I have to send maggie back to Magnuson to get intercooler replaced.
Old 07-17-2009, 01:48 PM
  #94
V-seriesTech's Avatar
buddy on here was racing a porsche on the highway one night from a 70 roll to about 170mph on SPRAY in his camaro,......bent 7 rods. Still ran fine. Other then the random multiple misfire.
Old 07-17-2009, 02:07 PM
  #95
D-Webz's Avatar
Procharger D1SC
7psi 520rwhp/470 rwtq
Mile at time of Install--98,000
Miles since install---135,000----37,000 on procharger, oil changes religiously
Motor is fine no problems, Ten bolt gone...LOL
Old 07-17-2009, 04:28 PM
  #96
Customizing Director
MadIceV8's Avatar
Updated. Need to pull some from pg4 still.
Old 07-17-2009, 08:20 PM
  #97
blue00ZZleeper's Avatar
D1SC Procharger,
Installed/not sure but well before 65K.....current mileage is 88K,
9psi 580rwhp/550rwtq
FMIC/good tune from CMS
P/P 241 heads + cam
Motor is fine, runs great....drivetrain needs help lol (stock rearend)
Old 08-14-2009, 02:11 PM
  #98
FNE WHNE's Avatar
I'm running AFR 205's 60cc (wow...) g5x3 on a 114, almost full bolt ons... F1-C (9.5#) motor's drinking methanol like it's water... making 643 to the wheels...
Everything is A-OK (so far) ... about 3k on setup
Old 08-14-2009, 03:27 PM
  #99
Subliminal Hit's Avatar
I posted on the first page and said I was pulling the stock motor and putting in a forged bottom end...well I didn't have the money so I've put another 3,000 miles this year now it's got 63,xxx.
I really cant believe it's still running strong, I've ran it up to 160 on the highway once, 140+ plenty of times, and countless first thru 3rd pulls on the street just messing around. I'm gonna run a few cars soon and see if this thing finally blows up, I'll check back in 1 last time and say if it goes boom and state what failure was.
Old 09-18-2009, 03:07 PM
  #100
MadIceV8's Avatar
Subliminal Hit - Updated.
I now listed this as a sticky.
Quick Reply: Stock Bottom & Boost - Reliability List
