Aluminum vs. Iron
Old 02-03-2009, 07:12 PM
99LS6SS's Avatar
Default Aluminum vs. Iron
If built properly, how much boost could an aluminum block handel? I want to build something to withstand atleast 20lbs of boost, would an aluminum block work or would it just be smarter to go iron and build a 408 or something along those lines
Old 02-03-2009, 08:11 PM
Shawn @ VA Speed's Avatar
Fireball was running 25-25 psi on his ls2 block with no issues,but if weight is not a concern i would always go with iron-less bore distortion and better ring sealing
Old 02-03-2009, 09:21 PM
Big Bird WS6's Avatar
go with ERL block. i am going to do that
Old 02-04-2009, 08:50 AM
99LS6SS's Avatar
Ya I wanted something that would make near 1,000HP but I wanted to drive it atleast a couple time a week
Old 02-04-2009, 10:20 AM
1000 wheel or flywheel?
Old 02-04-2009, 10:44 AM
MY99TAWS6's Avatar
I went iron not too worried about the extra weight.I am targeting around 1000rwhp max with some spray.
Old 02-04-2009, 11:45 AM
sr71bbjr's Avatar
x2 iron>aluminum
Old 02-04-2009, 12:03 PM
Fireball's Avatar
unless someone was crazy enough to fill the waterjackets with hardblok on an LS2 block
Old 02-04-2009, 12:08 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Did that crazy person do a half fill or a full fill I would imagine that even a half fill would help a lot to stabilize the cylinders.
Old 02-04-2009, 12:13 PM
Fireball's Avatar
some people are crazy enough to leave that decision up to their engine builder
Old 02-04-2009, 12:16 PM
Old 02-04-2009, 12:18 PM
99LS6SS's Avatar
around 1000 at the wheels. By around i mean anywhere from 900-1000 at the wheels. I'd be happy with that.
Old 02-04-2009, 12:21 PM
99LS6SS's Avatar
Would an LQ4 be strong enough or should i go strait to LQ9? I wanted to do a truck manifold setup pushing around 18-20psi with a decently size motor.
