Anyone had to replace bearings in the Procharger idler on the bracket?
Old 02-04-2009, 05:34 PM
Avengeance's Avatar
Question Anyone had to replace bearings in the Procharger idler on the bracket?
If so what part #? Or do I need to replace the whole idler?
Damn thing is squeeking like a SOB!
My Procharger bracket has both an idler and the idler/tensioner on it. The one squeeking is the idler only... I believe its the same bearing in both.
Thanks....
Old 02-04-2009, 06:45 PM
Blackbird's Avatar
If you haven't already try a search on here. Pretty sure there are threads from a ways back that talk about this and where to get replacements. I remembering it being a fairly hot topic a few years back.
Old 02-04-2009, 06:57 PM
99taws6's Avatar
I just replaced mine on my 8rib setup. The bearings were $11 each at NAPA
Old 02-04-2009, 07:16 PM
Avengeance's Avatar
Thanks guys....
Heath.. I did search, came up with a few threads but nothing significant.
Old 02-04-2009, 07:17 PM
Avengeance's Avatar
Do you happen to have a part number?
Old 02-04-2009, 07:29 PM
DarkFormula's Avatar
I bought mine at Napa as well. I had to take the bearing to them to have it matched with their stock.
Old 02-04-2009, 09:28 PM
Avengeance's Avatar
Thanks again... Ill pull it out and match it up.
Quick Reply: Anyone had to replace bearings in the Procharger idler on the bracket?
