Procharger Race Valve
Old 02-05-2009, 11:08 PM
SIKSIX's Avatar
Default Procharger Race Valve
How can you adjust one or is even adjustable. I think that might be y my car stops makin boost at bout 5500 rpms at only 10lbs.
Old 02-06-2009, 05:11 AM
EPP
EPP's Avatar
If the race valve was leaking boost at 10 psi you should be able to hear it. Bob
Is your ProCharger a 6 or 8 rib?
What pulley do you have on the head unit?
How tight is the blower belt?
Which valvesprings do you have?
Have you pressurized your intercooler system to check for leaks?
Old 02-06-2009, 11:09 AM
duff70's Avatar
belt slip
Old 02-06-2009, 06:31 PM
NAVY's Avatar
The same thing that I complain of it belt slip
Old 02-07-2009, 11:46 AM
SIKSIX's Avatar
I have a Reichard Racing 3.4 pulley, D1SC head unit, belt is really tight, Patriot Gold double valve springs, 8-rib belt. I havent made me a pressure tester yet to test the system.
Old 02-08-2009, 06:07 AM
NAVY's Avatar
i need 3.7 if you have
Old 02-09-2009, 08:59 PM
SIKSIX's Avatar
i have a 3.9 8-rib pulley, that was $80 from procharger that i dont need anymore
Quick Reply: Procharger Race Valve
