Fabricating a GTO Vortech for a WS6
Is it possible and is it worth it to custom fabricate an 05 GTO vortech supercharger kit to fit an 02 Ws6. Would it be easier to just buy the brackets and piping direct from Vortech? Any help would be appreciated. Thanks.
It will be easier to buy the right parts from Vortech. Get the P/N's from them, then order through a sponsor here or distributor - it will be cheaper. I fabbed up my own for a non f-body, but I had to work through alignment, flexing and tension issues, basically engineering my own reliable setup. It was a lot of work and some shredded belts (8-rib at $~35 a pop).
The Vortech site generally has Part Number links in all of its kits, so you can research the right stuff, confirm with them and order.
Jim
Jim
