4 inch stroker crank vs stock crank...FI application pros and cons???
Im boosting my stock aluminum 346...bare blocked it and found out i spun a rod bearing....so im wondering what i should do? I plan on 600-800rwhp with my setup. should i buy a stock crank and have it polished or just say **** it get the 4 inch and stroke it out to a 383? the engine is getting arp fasteners, forged rods, forged pistons, rings, h beam bearing etc...also wondering what a safe rwhp number is for my stock aluminum block? all input is greatly appreciated
keep in mind i want this to be very reliable and hope in only doing it one time
you will run in to head lifting issues at around 950whp, before the block goes. and if you have the money go with the stroker crank, it will help you make more power on less psi. good luck
