My Turbo is clock.. Question
Loosen both the compressor and the turbine housings, hold the "intake" and "exhaust" steady, while you rotate the center housing 180 degrees. Why do you have the center housing upside down?
I know this is not brain science it's upside down because I loosenthe bolts on the exhaust hosing side and the whole thing rotated together. So I want to loosen the 4 bolts on the compressor side? I don't want to f&$& this up
Only loosen the red circled bolts, do not loosen the red X holes.
ok, so do i want to remove the 4 bolts or just loosen them? what do the 6 bolts on the compressor for? do i need to loosen them too or just the 4 under them, i have loosen everything and it wont turn, just the exhaust side turns.
