Quick question about Procharger
Is it possible to run Procharger (D1 or P1) on a stock buttom end motor with 11.2:1 CR? The motor has 104k miles on it. The mod is ported 5.3L head with 224R cam, full bolt on and exhaust.
So with the listed mod and a P1SC, around how many whp I should expect?
Out of curious, how long did your Camaro motor last with 15psi? Are you using the standard twin cooler or the FMIC?
We got about 1,000 mils out of it at 15 psi. That was with the older twin 3.5" intercoolers. Here is a link to the car after it as resurrected. http://www.exoticperformanceplus.com...Car.php?car=12 Bob
8 psi is all I recommend as how psi may result in your engine needing rebuilt sooner than you can really afford to do so. Methanol injection is a good way to go as it will drop the inlet air temps by 35 to 40 degrees at wide open throttle, which greatly increases horsepower. Bob
ok, the 6.0 heads take the stock CR from whatever a stock LS1 is, say 10.5, to___ ??
Drops it to 9.5, 8.5.. I don't know, but would like to know. Do you know?
