Is this possible?
Is this possible?
Street cars what fuel systems are you running?
Alright guys i have a 98SS with an Incon Twin Turbo kit I have an External Aeromotive pro Series pump with a sump tank.I was wondering if theres anything I could do with my fuel system to make it more street friendly.Could I run another external pump on the passenger side for the street and put a switch on the bigger one for when I need to use it.Is that possible or any suggestions?
What do you mean by street friendly? What kinds of problems are you having now? What is your in-tank pump? (Remember, the external pump will always be limited by the smaller one in the tank) I suppose you could add another external pump and run it off of a hobbs switch, but three pumps is overkill-and from the sounds of things your setup is not right.
you can get a voltage controller that will reduce the heat by lowering pump voltage while cruising or at idle. The aeromotive pumps are notorious for heating gas in EFI applications.
