need to Reach 1000 hp 6.0L
I need to Reach 1000 hp with 6.0l iron block
with turbo , Are there any tips , and I hope someone help me for my setup
for drog race >>!!!
best regard
for drog race >>!!!
best regard
thanks for all of you
yes i have camaro , caprice , corvette zo6 7.0L ... 10 car
and all Advice and consultancy provided by the work of the elite and you are sure that you and the shelter that I find it the answer to all queries
now i going to make setup for iron block 6.0L by Use turbo to Reach 1000 hp
i know by Forged motor, 88mm truck manifold turbo kit, 96lb injectors, fuel pumps,
more Precise details about turbo boost , heads. diff , gear
for drag racing in bahrain >>>
thanks for lall s1tech member
i would reconsider your choice of block if you want to reach 1000whp. there is a big possibility of head lifting at those power levels with a 4 bolt per cylinder set up.
427 lsx should do the job but it is a Little pricey. but you have to pay if you wanna play.
good luck.
good luck.
The way I read his statement was 1000HP not RWHP. If this is the case, then this build would be fine with a 4 bolt 6.0l block setup. Any more than this, I would recommend A LSX Block or something else.
AFR Head,s, Trickflow,ETP head's, AllPro Heads, are all good choice's.
Probably between 16-18psi to make your power if you are looking for
1000HP(FWHP).
1000HP(FWHP).
good luck.
good luck.
I have seen many builds in various places pushing 1000rwhp or even a few hundred more that seem to be doing just fine with 6.0 iron block and decent thick deck 4 bolt heads like afr ,etc. I would say you don't need to go to LSX blocks until around 1500rwhp.
