FI on E85
Old 02-26-2009, 09:34 PM
dreamls1's Avatar
Default FI on E85
How many turbo guy are running E85 reliabe? I can't decide if I should go that route. I was told the octane rating is different evey time you go to the pump, so it hard to run a good tune. Anyone have problems running this fuel?
Old 02-26-2009, 10:13 PM
SPRAYED 01's Avatar
Im in the same boat as you. I have plenty of stations so it would be easy. I wasnt too happy about buying new injector again and a driver box but thats the FI world for ya.
I have never heard of anyone complaining about it on a fi application.
At about 105 octance and the cooling capabilities it seems a no brainer.
Alex
Old 02-27-2009, 07:03 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Since E85 is mandated to be 85% ethanol, I can not see the octane rating varying that much since the major of it is ethanol than that is determining the 'octane' rating. I am sure the 15% of other stuff and affected, but it can not be that drastic. From everything I have read E85 has about the same octane rating as 100 unleaded.
The main reason I have not switched over is that there are few stations here in Denver that carry E85. There is not a single station within 15 miles of my home.
Old 02-27-2009, 07:39 AM
BoostnTBSS's Avatar
E85 is great fuel... its like about 104 ish but you can tune it like 112-116.. it loves boost and timing and plus i run like 20-30 * cooler with it.. my new motor will be e85 on the street and e98 at the track so 16 160# inj will be needed if i dont stay blow thru...i dont see a 1500rwhp e85 car that hard, seeing a few vipers hit 1800rwhp on it...
Old 02-27-2009, 08:15 AM
veee8's Avatar
The variance at the pump, can sometimes be attributed to summer and winter blends. They add a little more gasoline in the winter to help cold light off, as E85 gets a little finicky in colder temps. It ends up being closer to E75-80.
Then there are the rumors that some distributors use a sub grade gasoline for blending. I don't know how true that is.....
The ultimate solution, and what I plan to do, is has the blend sensor in the fuel return line to measure the true Ethanol content in your tank. That is how the factory flex fuel vehicles do it.
Old 02-27-2009, 10:13 AM
Big Bird WS6's Avatar
he is right.
during the winter you will see e70 cause the car wont start in cold weather with e85,
e70 is around 100.5 oct. and e 85 is around 102 -104 depending on the pump.
so buy 20gallons of winter mix. put it in air tight can and wait till motor is dont. then tune it on that. then no matter what you are safe.
Old 02-27-2009, 10:14 AM
and a side not i am building a 10:1 compression motor. and going to push my turbos to there max. hopping 18psi. but i guess we can test the limit of compression
Old 02-27-2009, 01:20 PM
veee8's Avatar
I have not found the limit, 9.5 cr and I have logged 21 psi of boost with 24* timing, without any issues. I am still playing with it.
We have run much higher timing and boost on a lower compression LT4 with zero issues.
It is a great cheap boost fuel.
Old 02-27-2009, 03:03 PM
^ ^ ^ you serious? 9.5 and 21 cr. holy hell batman. so if i am going to only run say. 20 psi tops. should i increase my cr if i can do it for cheap.?
thanks
Old 02-27-2009, 03:35 PM
veee8's Avatar
E85 loves compression. It is very resistant to knock. If you are building a engine with E85 in mind, 9.5 cr, at least, is a great idea. Your off boost throttle response and overall drive ability will be a lot better.
If it were a gasoline engine, then lower cr would give you more room for error.
I stopped at 24*, and did not feel it was worth the risk to keep pushing it. It was picking up power every time we added 2*. I was way rich too, probably low 10's at high boost. I am still dialing it in, I will lean out the AFR a bit, but I probably won't mess with much more timing. Around 1000 hp to the tires now.
Old 02-27-2009, 03:39 PM
so building around boost. and e-85 running 10 cr or 10.5 cr is probly not bad.
now i understand that e85 isnt every where. so should i do two tunes. one for e85 and one for 91. with like no psi. lol
Old 02-27-2009, 05:20 PM
BuffJoeyD's Avatar
I use a 91 octane tune for my motor car when I need to go long range- But I need to take the computer with me some time and see how many freeway only miles I can get on a tank of E85-
Seriously noticing the Winter blend E70- Id hate to have my car boosted right now and not have accounted for the E70 change. ( I dont think it would be that bad but the difference is there )
Old 02-28-2009, 06:38 PM
red98ls1's Avatar
So, I am planning to do this as well. What are the 400+ CI guys using for injectors and driver box? (I have a 403 CI motor, by the way )
This is on my next list of to-do's since I am going through the car again.
Old 03-01-2009, 11:46 AM
MECHAM's Avatar
FJO's and 160's
Old 03-01-2009, 02:21 PM
what is FJO?
Old 03-01-2009, 02:33 PM
veee8's Avatar
It is a brand name.
Big Stuff 3 and 160's here,awesome drive ability.
Old 03-01-2009, 03:57 PM
themachasy's Avatar
Originally Posted by Big Bird WS6
what is FJO?
Company that makes driver boxes so you can run huge 160lb low impedance injectors on your stock ecu.
Old 03-01-2009, 04:26 PM
^ ^ ^ is it better then racetronix aem or versa system?
Old 03-31-2009, 04:55 PM
maxgee's Avatar
I run E85 on my boost application. Love it!
Taking a trip to GA from S. FL next week and running e85 up and back.
I hope GA is not using any e70 blends or I'll have to run 93 octane when I get into GA.
Old 03-31-2009, 09:25 PM
BoostnTBSS's Avatar
e85 loves the comp. i was about 9.5-1 with 72cc heads now run 64cc heads and it loves it. its like insta spool i have not fine tuned it but i have way more left. i did some real high timing pulls like 28-32 deg at 4-10 psi in break in and it loved the timing with no knock. i will back in down to 15-17 to start when the boost goes to 15-20 soon.... thats if the car willl stay on the road to make the boost.. its real light!!!!!
Quick Reply: FI on E85
