restrictor plate vs surgeline
Old 02-27-2009, 04:27 PM
jeejee's Avatar
Default restrictor plate vs surgeline
how will an inlet restrictor plate change the boost surge line on the left side of a compressor map ?
it will obviously move it to the left, but is there a way to determine how much ?
say for instance the supercharger needs to flow 300lb/min at 50.000rpm
or 300lb/min at 2.4 pressure ratio
could that be accieved with a correct restrictor ?
Old 02-27-2009, 05:24 PM
Gingervitis Addict
slow67's Avatar
It won't move the surge line. It will change your P/R, as it is seeing vaccum in front of the compressor instead of Atmospheric pressure. So if your motor is seeing the same boost, you are seeing a higher Pressure Ratio than before, because your compressor is working harder.
Old 02-27-2009, 05:51 PM
jeejee's Avatar
well i don't completely agree with that.
if say: i am at a 2.2 pressure ratio with 350lb/min
that is in the compressor surge area of the graph.
now when i restrict it and you say all it does is drop pressure ratio, this would mean it now falls outside the surge area and into a more workable area , so it does sort of change the surge characteristics of the supercharger
or am i missing something ?
Old 03-03-2009, 03:52 PM
jeejee's Avatar
nobody with experience in this ??
Quick Reply: restrictor plate vs surgeline
