F1 procharger on a stock block
Old 02-27-2009, 06:21 PM
01turdbird's Avatar
Default F1 procharger on a stock block
I was just wondering what is the lowest amount of boost you can make on a F1. I have a friend that is willing to sell me his used one but I wont have the money to forge the bottom end till I get back from the Philippines next January. So I was wondering if I could put it on now and run low boost and be ok till then. Right now the car has patiot heads and a tr224 cam.
Old 02-27-2009, 06:31 PM
'Trust''s Avatar
I don't know if an F1 will make a small enough amount of boost to be safe on the stock motor.
Old 02-27-2009, 06:42 PM
BLNLS1/RX7's Avatar
I dont think so.
Old 02-27-2009, 07:11 PM
Haans249's Avatar
Just buy it and throw it on, if your motor goes, then upgrade. Or just let it sit on the shelf until you have enough to forge your motor. No sense in letting a good deal pass you by if you're already planning it for the future.
Old 02-27-2009, 07:18 PM
z28boy's Avatar
You will need to have a custom pulley made to slow the blower down it's not the best set up but you will be able to get by. What is your compression?
Old 02-27-2009, 07:22 PM
99bowtieZ's Avatar
Just buy it, you can always sell it again. You may not get another deal to buy.
Old 02-27-2009, 09:10 PM
HotRod68Camaro's Avatar
I will let you know next week. Im getting my LS6 tuned next week, mods in sig. I threw on a 5" pulley so we'll see how much boost/power it makes.
Old 02-28-2009, 05:57 AM
EPP
EPP's Avatar
A 5.50 inch/5.75 custom made pulley will get the boost down into a safe level. Your 5.0 inch pulley will most likely make too much boost. Bob
Old 02-28-2009, 06:59 AM
5" is the largest Procharger said would fit on the kit
Old 02-28-2009, 09:35 AM
z28boy's Avatar
You need to have a custom pulley made. I run a custom 5.5 on my f1A.
Old 02-28-2009, 10:55 AM
SilverSS's Avatar
I'll trade you for my D1SC. Problem solved!
Old 02-28-2009, 11:37 AM
Frost's Avatar
this problem seems to be going around right now, doesn't it BOB!
Old 02-28-2009, 11:39 AM
Frost's Avatar
which blower are you running? The A, C, or R?
Old 02-28-2009, 12:13 PM
I have a F1-C
Old 02-28-2009, 05:30 PM
EPP
EPP's Avatar
Yes, it does indeed! lol Bob
Old 03-01-2009, 07:11 AM
whiteboycntdnce's Avatar
Old 03-01-2009, 06:55 PM
01turdbird's Avatar
Would there be any difference between running a d1sc at 8 psi over a f1 at 8#
Old 03-01-2009, 08:44 PM
11Second Club
Gauge's Avatar
I'm no expert, but centrifugal superchargers are supposed to be more efficient at higher impeller RPMs. Now, that is only true to a point. They do eventually start to lose efficiency. However, the D1-SC will probably be more efficient at 8psi than the F1 because that's not really spinning the blower very hard.
If you can buy the F1 from a friend and then get a good deal on a trade (i.e. get some cash + a D1SC), then that's the route I would go... assuming your goal is 13psi or less on stock displacement.
Old 03-02-2009, 08:22 AM
Dumb Ass Vette Moderator
ls1290's Avatar
The F series blowers have a higher step ratio and that will make the boost start to build sooner.
Old 03-02-2009, 04:35 PM
black01_WS6's Avatar
What size CI are most of the F series blowers running? Just trying to see if the F1 could be in my future or not. I was going thru the same question as the OP.
Quick Reply: F1 procharger on a stock block
