PCV Catch Can help, turbo STS. Pics inside
I need help with a proper setup of my pcv system. I purchased a catch can and air oil seperator. I have truck valve covers so there is one port on the front of the passenger side in the front and the drivers side has a pcv style port in the rear. The two valve covers are Tee'd and running a pcv inline to one port on the catch can. the other port on the catch can is running to a air oil seperator then to the intake. The bottom port on the catch can is running to the intake pipe before the turbo all the way in the rear of the car.
according to post #70 in the link above, should i block the throttle body port. i thought the catch can bottom port goes to the turbo inlet, also my catch can has two inlet ports. im getting heavy oil on my plugs now she wont start
