harlan 2 step.... will it build boost
Old 03-03-2009, 10:20 PM
extremetoy's Avatar
Default harlan 2 step.... will it build boost
im looking at getting a used harlan two step and since it doesnt have the ability to retard timing, will i still be able to build any boost at the line in a 6 speed?
thanks, Gary
Old 03-03-2009, 10:35 PM
Frost's Avatar
Absolutely! Mine would make 5psi in about 3-4 seconds as-installed with no tuning for it.
Old 03-03-2009, 10:53 PM
black98ws6ta's Avatar
Agreed.
Old 03-03-2009, 11:31 PM
extremetoy's Avatar
sounds good, just sent the money
thanks
Old 03-04-2009, 03:24 PM
donnyshane69's Avatar
How would that work on a rear mount with a six speed.
Old 03-04-2009, 05:49 PM
extremetoy's Avatar
ill let you know the 10th of this month as long as fed ex is on time im hoping good
Old 03-04-2009, 06:41 PM
PBMGoatM6's Avatar
Where can you order these? Their website says they dont sell them anymore
Old 03-04-2009, 07:49 PM
cablebandit's Avatar
lok on ebay for the Lingenfelter version which has timing retard built in which you need for the 6speed
Old 03-04-2009, 08:07 PM
Frost's Avatar
It should help, but mine worked just fine and relatively quickly without the retard and I have a six speed. A lot of the speed depends on the RPM you set it at. At 4500 mine would come in really quickly.
Old 03-04-2009, 08:20 PM
extremetoy's Avatar
yea i think he doesnt sell them anymore... im getting it used off here
frost, is yours a rear mount or a front mount... also what rpm does yours start and finish building boost in 4th gear
thanks, Gary
Old 03-04-2009, 08:40 PM
Frost's Avatar
Mine is a front mount. In 4th where load is high, I'd have to log to say for sure but it comes on WAY low.
Old 03-04-2009, 11:22 PM
Chris Stewart's Avatar
I also have a Harlan, got it used. It works great with a 6 spd, and gets me about 4-5psi too, normally set at 4500-5000. Even if you don't build much boost, they are spooled up when I release the clutch. There is no lag and boost comes on instantly! Love it! Also nice just because the launch rpm is set, so you can mat it and focus on the tree.
Even though they're not made anymore, there's still LPE and Synergy available to do the same thing and more. I hear that Synergy has a cool transbrake feature for the automatics.
Old 03-04-2009, 11:30 PM
extremetoy's Avatar
ahhh your getting me all excited
Old 03-04-2009, 11:41 PM
eviltwin_1987's Avatar
ah me too
Old 03-11-2009, 03:23 PM
extremetoy's Avatar
right now i have it set at 3400 and in a couple seconds it made .7 psi according to the eboost
how long is it safe to stay on it?
Old 03-12-2009, 02:00 PM
Nickn20's Avatar
thanks, Gary
You sound reallllly familiar. haha.
Old 03-26-2009, 05:57 PM
Denali08's Avatar
How does it work? What does it do exactly? Is it required with Auto and high stall/transbrake?
Old 03-26-2009, 10:00 PM
extremetoy's Avatar
haha, just saw this... whats up
Old 03-26-2009, 10:10 PM
WS6HUMMER's Avatar
I cant get mine to build boost, have it set at 5k and it will get up to about a half a pound of boost and thats about it.
Old 03-27-2009, 09:01 AM
Frost's Avatar
leaky pipes feeding the turbo? At 4K mine brought my 76mm GTS up pretty darn fast. If I let the car put more fuel into it it came up even faster...
Quick Reply: harlan 2 step.... will it build boost
