Size and thread count of studs on truck manifolds?
Does anyone know the size and thread count on the studs that come welded to the truck manifolds? I dont want to have to take them off and bring them to the hardware store.
Also, what hardware are you guys using to mount your T4 turbos to their flanges?
I meant configuration and size. For instance, my T4 flange on the merge is threaded. I got some M12 bolts to match up with the threads. When I looked at the flange on the turbo, there is no way to get a long M12 into the hole due the exhuast housing being in the way. This makes me think that perhaps I should tap the back bolt holes and stud them on the turbo. Then have the hot-side flange have the other 2 studs. Get the back 2 from the top and the front 2 from the bottom. sound good?
