how much boost on stock internals
Old 03-09-2009, 01:12 PM
500@10psi's Avatar
Default how much boost on stock internals
how much boost can a stock internals lq4 handle? ..... safely. I dont want to add a meth kit and the car is gonna be mostly street driven so i want to run on 94 oct. or less. what kind of psi #s have you guys used the cr. is 9.5:1 Thanks in advance for any info
500@10psi is offline
Old 03-09-2009, 01:39 PM
extremetoy's Avatar
it could prob handle 500hp at 10 psi or so
extremetoy is offline
Old 03-09-2009, 02:25 PM
500@10psi's Avatar
hmm good one......... that was on an ls1 that i blew up hence why i went with the lower comp. and bigger ci of the lq4. i was planning on going forged internals next winter but i dont want to screw this motor up in the mean time seriously it shouldnt be too hard of a question ..........
Old 03-09-2009, 02:27 PM
dreamls1's Avatar
i know i guy that went 14psi 590whp on a stock ls6.
dreamls1 is offline
Old 03-09-2009, 02:41 PM
500@10psi's Avatar
really almost a bar on that kind of comp? that makes me feel alot better. has he had any issues with it?
Old 03-09-2009, 03:16 PM
11 Second Truck Club
JJ_TURBO's Avatar
I was running 10psi and dyno 515rwhp but when I went to 14psi it did run well for sometime until it burned a pistons.
JJ_TURBO is offline
Old 03-09-2009, 03:23 PM
Badass94z's Avatar
I just finished my LQ4 mustang project and it made 640whp on 14psi through a big stalled auto 80mm Turbo on a stock lq4 other then 02 zo6 cam and springs
Badass94z is offline
Old 03-09-2009, 04:19 PM
500@10psi's Avatar
which motor was that on (assuming ls1) thanks for the info btw
Old 03-09-2009, 04:47 PM
Gordon0652's Avatar
Rods can take about 500-550rwhp. I wouldn't push more than that. If it was my car i would only do about 500rwhp at a max boost of 7-8#s.
EDIT: which ever comes first.
Gordon0652 is offline
Old 03-09-2009, 07:38 PM
extremetoy's Avatar
i was also being serious at the same time.... im sure you could get more than that but it sounds like you want to keep it somewhat safe as well. realistically i think the 500 will come before the 10 psi (depending on the drivetrain)
Old 03-09-2009, 09:13 PM
500@10psi's Avatar
thx man your right about trying to stay safe after i blew the last one the car was down for 2 years before i grew the kahonies to put a new motor in myself i just couldnt justify the 5k price tag the mechanic quoted me and that was for a ls1 motor with unknown mileage
Old 03-09-2009, 09:27 PM
WS6HUMMER's Avatar
What kind of fuel? I have been curious if you could do 10 on pump gas.
WS6HUMMER is offline
Old 03-09-2009, 10:08 PM
Silver_TransAm's Avatar
I usually run 10psi as well and even up to 14psi on 93octane fuel no meth. I do have 317 heads though.
My buddy has higher comp heads and is going to run 8psi on his aps kit. Its all in the tune.
Silver_TransAm is offline
Old 03-09-2009, 10:27 PM
SPLATT's Avatar
silver, any numbers yet?
SPLATT is offline
Old 03-09-2009, 10:33 PM
LS1Silverado05's Avatar
Hope your thread lasts longer than mine...
LS1Silverado05 is offline
Old 03-09-2009, 11:07 PM
ItsNotStock's Avatar
Buddy of mine has a turbo on his Silverado SS. Stock he had it as 12psi until one of his pistons gave up (#8 go figure). They think it was due to a bad tune. He now has it rebuilt to stock specs with slightly lower compression 9.5:1 and it running 10 psi I believe.
ItsNotStock is offline
Old 03-09-2009, 11:31 PM
Have a dyno/retune apt on wed. I think my injectors will cut the runs short though, but I'll find out soon.
Old 03-09-2009, 11:44 PM
SPLATT's Avatar
awesome, make sure you post what you get. I would also imagine injectors as the limiting factor. but a graph would be awesome. good luck!
SPLATT is offline
Old 03-10-2009, 04:54 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I ran 32 psi with my P1SC back in the day. All with a 3.4 pulley.
Urban Legend is offline
Old 03-10-2009, 07:37 AM
moehorsepower's Avatar
Definition of How much Boost vs How much Horsepower vs How safe....sure you can run boost till you peg your guage (at least once) What kind of horsepower are you looking for? if you can make you goal at a lower PSI then it will be safe,(providing you have a spot on tune) say app 500 RWHP @ about 7-9PSI. but if you need to make the same amount of HP @ 12+ PSI then the Grim Reaper is just a loud pedal away. Beware of people running an X amount of boost. Their geographical location makes a difference, altitude, air density, octane ect. Just be realistic and know all the "OTHER" parts that will need attention as the HP & TQ go up, Clutch and or Convertor, Drive Train, Fuel System ect. It dominoes very quickly.....
moehorsepower is offline
Quick Reply: how much boost on stock internals
