Lt1 block + boost
Old 03-09-2009, 10:07 PM
rg96lt1's Avatar
Default Lt1 block + boost
How much horsepower can the LT1 block handle ? Callies crank , Lunati rods, diamond pistons , splayed caps, arp head studs , arp rod bolts, AFR 227 heads with a gt47-88mm turbo . I know im ok with the internals , just wondering on how much the block can take before cracking .
Old 03-09-2009, 10:57 PM
NovaCain383's Avatar
If if is poured, I have seen them upwards of 1000 FWHP.
Old 03-09-2009, 11:06 PM
otherwhitemeat's Avatar
at 900rwhp you get a summer out of it ...after that bearings wear out fast and lt1 heads don't support to much more anyway.....I got 1100rwhp out of my lt1....but it burns through bearings so...now its a dart block..SBC
Old 03-09-2009, 11:51 PM
94dragbird's Avatar
I think there is one person over on camaroz28.com that went 1200 fwhp with a half fill and F1
Old 03-10-2009, 08:22 AM
engineermike's Avatar
I'm at 900-950 fwhp and 17 psi boost. It's .060" over and has been together for a couple of years now.
Old 03-10-2009, 10:00 AM
Yup....at about 900hp at the tire, and up...the motor won't last long. I think the block, even with fill, flexes to much...
Old 03-10-2009, 10:35 PM
LT1_Fireman's Avatar
355 is the way to go... I was 900~fwhp@ out of a 355 and D1(not d1sc) on my new setup I hope to make 1100~fwhp and I am staying 355 and going half-filled.And check this out...http://www.youtube.com/user/lcvette1, and here are the details...http://ltxtech.com/forums/showthread.php?t=2117
Old 03-10-2009, 11:09 PM
rg96lt1's Avatar
Guess we'll just have to find out then
Old 03-10-2009, 11:35 PM
elias_799's Avatar
i would save the money for an lsx block. a 427 maybe ? you get 6 bolt heads witch will prevent quite a bit of head lifting issues. and he block is proven to make over 2000whp.
Old 03-10-2009, 11:38 PM
Just get a SBC dart block and be done with it..
Old 03-11-2009, 12:14 AM
With the Lt1 block head lifting wont be the problem we have 5 bolts per cylinder and you can make good power without having to go lsx.(even tho I wish I would have.lol)
Old 03-11-2009, 09:25 AM
yup i have seen 33psi with no issues and a buddy has seen just over 40 psi.... but the blocks strength and lt1 heads are an issue so,.. time for a dart block and much bigger heads...
Old 03-11-2009, 09:13 PM
Jditlfm's Avatar
Otherwhitemeat, do you think a half filled 355 would live a long time at 900-1000 rwhp? If not how much hp could you get out of it while keeping it alive for about four years?
Old 03-11-2009, 09:22 PM
gosh how much power are you making?
Old 03-11-2009, 09:32 PM
elias_799's Avatar
i heard lt1's don't last for too long because they all like to eat bearing. could be wrong, i do not have much experience with LT series motors.
Old 03-12-2009, 01:43 PM
It think 850ish rwhp might last a while...as long as there is zero detonation and your not into it too often.....bearings and rings wear out fast...i think the block flexes too much...
Old 03-12-2009, 01:44 PM
1100rwhp
Old 03-12-2009, 01:56 PM
96lt1m6's Avatar
http://videos.camaroz28.com/recentvi...c7016f0c46.htm
http://www.youtube.com/watch?v=9fGQiIlyHTM
stock weight
Old 03-12-2009, 04:23 PM
At ~950 fwhp, I can see evidence of cap-walk with a 4-bolt conversion, but that's the extent of damage. Going to a dart block isn't going to help that unless you dowel the mains.
Old 03-12-2009, 04:33 PM
It will help at 1300rwhp... I have seen premature main bearing wear and ring wear. BTW, I have seen videos of factory blocks on the dyno, under some special camera and lights...you can watch them flex....it pretty bad! I try to find a link.
Quick Reply: Lt1 block + boost
