changing Procharger F1 oil...
Old 03-10-2009, 09:55 PM
SELLSZ06's Avatar
Default changing Procharger F1 oil...
I am chaniging the oil on my F1 and I am wondering if there is a way or anyone know of a trick to change the oil without taking it off the bracket? Is there a way to suck the oil out of the blower while it being mounted. I've change it before but taking the blower down, i know this is pure laziness of my part.
Old 03-10-2009, 09:58 PM
chevyz2801's Avatar
My d1sc has a drain plug on the bottom dont know about the f1.
Old 03-10-2009, 09:59 PM
SELLSZ06's Avatar
yes, but if its pointing down how you fill it back up?
i just trying to get around taking the blower off, not that its super hard
Old 03-11-2009, 12:16 AM
chevyz2801's Avatar
i have a filler/dipstick on the top
Old 03-11-2009, 01:44 AM
BigRich954RR's Avatar
Dipstick on top uses a flat head screwdriver to remove. the drain plug i think is 5/8. It has a magnet on the plug that needs to be cleaned
Old 03-11-2009, 04:43 AM
chevyz2801's Avatar
Right
Old 03-11-2009, 12:39 PM
11Second Club
Gauge's Avatar
Is there enough room to get the bottle over the top of the blower so you can fill it up? I haven't done my first oil change on my D1SC, but it's about that time.
Old 03-11-2009, 01:45 PM
chevyz2801's Avatar
dont know haven't put my blower on yet
Old 03-11-2009, 02:23 PM
11Second Club
Gauge's Avatar
I have, but when I filled it, the radiator wasn't in the car. So, with the radiator, I have no idea how much room I'll have to work with.
Old 03-11-2009, 03:46 PM
SELLSZ06's Avatar
I have room I am thinking of using a syringe to suck it out
Old 03-11-2009, 10:41 PM
dlandsvZ28's Avatar
On my D1 I drained same as you drain oil from the oil pan (remove the plug).
To fill I used a small funnel with a long snout. It's pretty much straight down into the filler hole on a D1. If you can see it - you can fill it.
And if that doesn't work you can always attach a hose to the funnel sticking the end of the flexible hose tubing into the blower. Most time consuming for me was to not over fill it. It seemed as if not all of the oil is removed when draining.
The manual explains exactly how to drain and fill.
Quick Reply: changing Procharger F1 oil...
