Our NEW Set up from ....
Old 03-11-2009, 10:16 PM
my first GTO's Avatar
Default Our NEW Set up from ....
We think this is The Only one with this set up.....frank
Thanks To doug and Chris from ECS.....not bad Work.....
Old 03-11-2009, 10:45 PM
Jimmy P's Avatar
Looks like a nice setup. Any reason why this wouldn't work on a F-body?
Old 03-11-2009, 10:48 PM
elias_799's Avatar
nice
Old 03-11-2009, 11:28 PM
I'm Mike Hutto
Rapin'Ya's Avatar
The fuel lines are way overcomplication...Remeber the acronym. K.I.S.S.
Keep it simple stupid. The Ts hurt fuel flow more then a Y does. Use the main feed to split off a into a Y. From the Y feed both front rails the lines from the back of the rail run into each side of the regulator and use the bottom of the regulator to dump it back as a return. Much neater.
Old 03-12-2009, 12:22 AM
Silver_TransAm's Avatar
First time I have seen that done to a goat. Nice project.
Old 03-12-2009, 02:37 AM
chevyz2801's Avatar
Looks good.
Old 03-12-2009, 03:00 AM
chuntington101's Avatar
looks really good! what are the reasons for using the Vette brakets rather than the GTO's???
also what size is that head unit??
Chris.
Old 03-12-2009, 08:22 AM
Chris.
the Unit is a Novi 2000 as For the brackets The vette work better than the GTO....
Old 03-12-2009, 08:32 AM
1INSANEGTO's Avatar
Engine bay looks like mine. IE No ABS, Crusie, etc.
Old 03-12-2009, 10:55 AM
STAR's Avatar
Looks awesome! Couple of questions for you:
1. What size pulley on the blower?
2. How is the intake tube attached to the blower?
That belt looks like a 10 rib set up. Did you convert to a manual rack as I see no power streering pump?
Old 03-12-2009, 12:20 PM
1. What size pulley on the blower?...2.75
2. How is the intake tube attached to the blower?....two set screws
Yes we did and Manual Brakes......Frank
Old 03-12-2009, 01:04 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That looks really nice. There's a few things I would have done differently, but I like the clean and symetric look.
Old 03-12-2009, 02:37 PM
STAR's Avatar
2.75 blower pulley and 8" crank pulley, how much boost are you planning on making? Also, what size motor do you have in there? It looks like you might be the fastest GTO in the nation!
Old 03-12-2009, 03:00 PM
about 18 to 22 psi it's a 370ci ......we may be the fastest IRS gto.....
Old 03-12-2009, 03:20 PM
Dumb Ass Vette Moderator
ls1290's Avatar
The plumbing looks like my first nitrous setup....spaghetti city.
Old 03-12-2009, 05:02 PM
allthrotle's Avatar
Holy cow batman! that looks like a beautiful mess.
Very nice gto. Lets see some track times.
Old 03-12-2009, 05:03 PM
stevensLS1's Avatar
Quick Reply: Our NEW Set up from ....
