[PICS] Katech Performance Air Attack LS7 D1SC. 865hp/735tq
Old 03-12-2009, 02:50 PM
LS1TECH Sponsor
Katech_Jason's Avatar
Default [PICS] Katech Performance Air Attack LS7 D1SC. 865hp/735tq
Here is a great package for all you horsepower freaks out there. Yet another variation of the monster AIR ATTACK LS7 is now available, the AIR ATTACK LS7 D1SC. We use a D1-SC Procharger to fit under the hood constraints of a Corvette.
We don't install this package here due to emissions constraints. Choose your favorite local tuner, pull the engine and send to Katech, then we send your complete package back to your tuner for installation and tuning.
The package consists of:
Air Attack LS7 engine build
-Katech forged pistons
-DLC coated pins
-Callies H-beam rods
-Callies Dragonslayer crank
-ARP head studs
-ARP main studs
-Lingenfelter billet steel main stud girdle
-Piston squirters
-Air Attack LS7 camshaft (supercharger spec)
-High lift springs
-Titanium retainers
-High speed lifters
-C5-R timing chain
-160 deg. thermostat
-ATI damper
Procharger D1-SC kit for Corvette Z06 (complete tuner kit)
Fuel injectors
Dynamometer break-in and power validation (with supercharger)
865hp & 735tq @ 10.5psi
All this for only $21775.
Seen here are also optional:
Katech carbon fiber valve covers
Show prepped and painted intake manifold
Not pictured:
APS twin in-tank pump
Aeromotive boost-referenced fuel pressure regulator
-6AN braided steel fuel lines, filters, and check valves
Coil relocation kit
You may ask why the dip at 5400rpm. It is tuning related. Since we are not providing a calibration to the customer (it is the responsibility of the tuner) we did not do a comprehensive tune on the engine dyno. The engine dyno test was simply for break-in and power validation.
