Turbonetics TC-76 Downpipe
Old 03-12-2009, 09:13 PM
dreamls1's Avatar
Cool Turbonetics TC-76 Downpipe
I guess this is a dumb question but I want to get it right. How does my downpipe mount to the turbo? I was thinking V band but there are hole in the exhaust housing and came with a gasket. Just not sure how I hook it up.
Old 03-12-2009, 09:24 PM
crashly's Avatar
has is got a flat machined area , and 5 bolt holes ??
Old 03-12-2009, 09:31 PM
dreamls1's Avatar
It's got 4 holes
Old 03-12-2009, 10:01 PM
crashly's Avatar
whats the part number turbine housing ??
is it ' on centre" , tang ?
i thought the on centre turbines where the only ones with 4 bolt outlet ??
Old 03-12-2009, 10:33 PM
dreamls1's Avatar
not sure what the part # is here are some pics
Old 03-12-2009, 10:47 PM
black98ws6ta's Avatar
thats a on center exhaust housing...not what soemone would typically want unless they are going for a symmetrical look or have space constraints.
Old 03-12-2009, 10:49 PM
dreamls1's Avatar
So what should I do?
Old 03-12-2009, 10:54 PM
You planning on building a kit around that turbo?
Old 03-12-2009, 10:56 PM
dreamls1's Avatar
yes why
Old 03-12-2009, 11:03 PM
If you just got it and you are building a car around it you may want to exchange for a tangential exhaust housing. If you cant easily get rid of it then you can run it, depending on your goals it may work fine. Many places sell a 1/2 thick 4 bolt flange for that outlet.
Old 03-12-2009, 11:14 PM
crashly's Avatar
see if you can swop it for a tang housing.....
cool dog, just like mine, always getting in to things.....
Old 03-12-2009, 11:16 PM
dreamls1's Avatar
Who can I swap it with?
Old 03-12-2009, 11:18 PM
crashly's Avatar
who you buy it from ???
try Dr Turbo or Jose
Old 03-13-2009, 12:11 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Well sell the donut flange for that turbo if you need it. That is the exhaust housing used on the old QMP and TTI street kits. They require on-center housings.
Old 03-13-2009, 06:33 AM
needaz28's Avatar
you can buy a 3"4bolt to v band flange. there like 60 bucks all over the place..
pm me if you want a link.
Old 03-13-2009, 07:29 AM
dreamls1's Avatar
I was only going to run this turbo for a season. Is it worth changing it up? Will i notice a big difference? I am only going to run 550-600whp.
Old 03-13-2009, 07:35 AM
smokinHawk's Avatar
no it probably wont make much of a difference at all especially if your only wanting 550-600
just get the doughnut flange
Old 03-13-2009, 06:22 PM
dreamls1's Avatar
where do i buy a 4 bolt to Vband flange that works for this turbo?
Old 03-13-2009, 07:33 PM
smokinHawk's Avatar
its not a vband flange, but a 4bolt doughnut flange you need for it, like posted above forcedinductions has them
Old 03-13-2009, 09:19 PM
Johnv's Avatar
may pay to get a tang housing for it now, if you plan on turbo swaps in the future as you will be making your manifold to suit and it will give you less turbo options down the track.
Quick Reply: Turbonetics TC-76 Downpipe
