getting no boost!!!
Old 03-13-2009, 12:51 PM
adam120674's Avatar
Angry getting no boost!!!
Not getting any boost, boost reads vacume at -20 until i hit about 55 then go to -10. Hits 0 boost when I'm on the gas. Maybe 2 if I floor it and shift hard. cold pipe seems ok (I can't be leaking that much). I have a t4 turbo with a 2" outlet , exhaust side is 3" , Exhaust A/R .63, Charge A/R .50. Changed the intake pipe from 3" to 2" until the MAS. Thought the turbo couldn't fill the 3" pipe. Any Ideas what to look for?
Old 03-13-2009, 12:57 PM
sujomatt's Avatar
Is the turbo still good? can you see if its still spinning?
Old 03-13-2009, 06:07 PM
KOOSWS6's Avatar
Is this a new set up? What kind of waste gate? How do you control your boost? I made the mistake of taking out my waste gate spring when I added a boost controller.
Old 03-13-2009, 11:11 PM
TripleWhite96's Avatar
I had that issue and it was my wastegate stuck open
Old 03-14-2009, 10:37 AM
adam120674's Avatar
thanks for your help, noticed the blowoff had a spilt o-ring,replaced it. After I drive the car. I'lll check the wastegate, if it still doesn't work. turbo is spinning fine
Quick Reply: getting no boost!!!
