air to water IC ?s
Old 03-15-2009, 07:17 PM
94dragbird's Avatar
Default air to water IC ?s
Well since this is a drag car only it won't be moving that much making an a2a IC a little less optimal than an air2water set up in this situation. I plan on running it in the same place that most people run there a2a setups(somewhat like the locations the EPP kits use) and was woundering what deminsions for the IC, also inlet and outlet locations and sizes would be nice. Also, does anyone have recommendations on a brand?
Thanks, Mike
Old 03-15-2009, 07:52 PM
tim99ws6's Avatar
I run an X0Z version. I think mine came with a 3.5" in/outs, but we cut them out and put in 4" in/outs. I'll have to re-measure it, but i think the core is 9.5" thick.
Edit: I "think" the MSD special edition CTS-v car that was in GMHTP was running the same intercooler in their setup as well.
Old 03-15-2009, 09:43 PM
94dragbird's Avatar
Do you have any links or a website where I can take a look at them?
Old 03-16-2009, 07:25 AM
Fireball's Avatar
you need to match the size of the I/C to your anticipated power potential...
Old 03-16-2009, 09:23 AM
LS1TECH Sponsor
Steve Burger's Avatar
Take a look at our site. We can get you set up with the right IC for your goals. I will be running a 2000 HP rated IC in the nose of my car.
Old 03-16-2009, 10:55 AM
94dragbird's Avatar
I was looking at somewhere in the 900 to 950 rwhp range.
Old 03-16-2009, 12:55 PM
LS1TECH Sponsor
Th 2000 HP one we sell woudl work well. We can get a smaller 1500 HP version if needed.
Pictures are on our site.
Old 03-16-2009, 02:44 PM
stangeater01's Avatar
Smile mine
22"wide, 13"wide, 14"tall
here is mine
i am starting my build
i was told it would support 2000+ hp
Old 03-16-2009, 02:49 PM
tim99ws6's Avatar
Looks Expensive....and nice!!!
Old 03-16-2009, 03:04 PM
7 Second Club
Phil99vette's Avatar
Chiseled Performance
Mount it somewhere in the center of the car and low
Use a good pump mounted intank
Don't skimp on the line size
Old 03-16-2009, 03:45 PM
94dragbird's Avatar
Can you PM me a price on one of you 1500 hp setups?
Old 03-16-2009, 03:46 PM
94dragbird's Avatar
Are you talking about mounting the tank or the IC low?
Old 03-16-2009, 04:08 PM
7 Second Club
Mount the IC in the center of the car and low as you can get it.
Old 03-16-2009, 04:22 PM
LS1TECH Sponsor
The intercooler line we sell is Chiseled Performance. We work with Robert and have a setup that mounts in our bumper support. This puts the weight low in the car. It also surrounds the IC from potential damage.
The IC 1500 is 1300.00
The IC 2000 is 1400.00
V Band flanges are 120.00
A Powdercoated bumper support with mounts for the IC is 269.00.
I have several pics on our site in the gallery section for my car as well as the FI section of the IC mounted.
We can work on a tank setup as well. There are lots of options there too.
Old 03-16-2009, 10:32 PM
94dragbird's Avatar
What does mounting it in the center of the car help with? IATs I'm guessing?
Old 03-17-2009, 07:35 AM
Fireball's Avatar
center of gravity...
Old 03-17-2009, 08:00 AM
LS1TECH Sponsor
As well as weight transfer.
Old 03-17-2009, 08:13 AM
94dragbird's Avatar
I still have alot to learn Thanks for the help guys. I will probably go with the center of the car route.
Old 03-17-2009, 08:18 AM
Fireball's Avatar
its not required...
I run mine in the nose of the car (sorta)
http://home.comcast.net/~tfranklin5580/coldside_2.jpg
Old 03-17-2009, 08:37 AM
94dragbird's Avatar
I'll deff. give it some thought. I have all summer to think about it while I gather the rest of the parts. Leaving it stock to run the '09 season. It does pretty good for only having 4.10s, headers and suspension and running 8.27 1/8 mile
