Crushed bent pipe ok for turbo piping
Hey guys, I was wondering if crushed bent pipe is ok to use with a turbo, I don't have any local shops that have a mandral bender around me and Im not the best welder . I am going to be using the truck manifolds and mount the turbo up front on my 5.3 in my regal, will I lose horsepower by using that kind of pipe, if so, how much?
Also can I use 16 gauge aluminized pipe for the intercooler piping( that would also have to be crush bent)
Any help will be appreciated.
Thanks
Thanks
You will lose about 20-30% of the flow and make your system less responsive. Simply turning up the boost a little will not remove the restriction. Do it right the first time - mandrel bends are not expensive.
PM sent.
Jim
PM sent.
Jim
I doubt you would even notice a difference. Just calculate your diameter of the tubing by the smallest spot. So you if you went from 2.5" and the crush marks make it 2.375" you just have slightly smaller..but would it matter? Most likely not Depending on your over all goal and if your tubing size was border line anyways. You wont lose 20-30% of the flow unless the tube is crushed 20-30% closed. The smaller tubing would actually increase the velocity, its not going to make it less responsive.
Dumb Ass Vette Moderator
Really??!?!? The flow characteristics are not solely defined by the diameter of tubing. The wrinkles in the bends will definitely affect the flow. Air flow in general does not like to go around bends, but when you throw in the wrinkles in the bends they will affect the flow a lot more.
a bunch of places off pre-bent pipes u can just buy and use couplers to put them together. example of a place is summit - not sure if any sponsors here offer that but definitely look into that.
11Second Club
I bought pre-bent aluminum pipe from CXRacing on ebay, cut it, mocked it up on the car, indexed it, took it to a speed shop, and had them weld it. Total cost was less than $300 for the pipe and the welding.
