HX52 turbo
Old 03-17-2009, 03:35 PM
importkiller_SS's Avatar
Default HX52 turbo
I was looking at the HX52 turbo and i can get one from a buddy for cheap! and i was wondering how that would do on a stock cube ls1 w/ some 317's and a truck manifold setup?
any suggestions about anything else would be helpful
thanks
Old 03-17-2009, 09:10 PM
LS1TECH Sponsor
DrTurbo's Avatar
Need more info then that. What is the part #??? Their are alot of HX52's. Vary from 66mm to well over 74mm
Old 03-17-2009, 10:10 PM
o dang, i didnt know there were different types of HX52's ill check when i get a hold of it
Old 03-18-2009, 03:50 AM
deuce_454's Avatar
HX52 is about the size of a t70 so it could work.... but find out what size it actually is before you go and buy somthing that is too small
Old 03-18-2009, 05:56 AM
what would be the perferred A/R?
Old 03-18-2009, 06:35 AM
deuce_454's Avatar
that depends on what you are looking for... max power, fast spool, powerband etc... are you keeping the 233/239 .598/.603 cam... and what is the LS?? if you are keeping the 3500 stall then you can go rather large and still have full boost when you mash the throttle....
id go larger than 1.1 but oppinions on turbo are like ******** :-)
Old 03-18-2009, 08:42 AM
i really want to keep the 233/239, the lsa is 113
Quick Reply: HX52 turbo
