Downpipe w/ Truck Manifolds
Old 03-18-2009, 02:29 PM
LS1Silverado05's Avatar
Default Downpipe w/ Truck Manifolds
Those of you running the truck manifolds facing forwards with a stock K-Member...where are you running your down pipe, and what size can you fit? I have looked at many many pics but haven't found one of where the downpipe goes on stock K-Member...Description or pics would be great. Thanks!
Old 03-18-2009, 03:21 PM
SINISTER's Avatar
when i had a stock ka member i believe i had 3inch going thourgh the passenger side..
do yourself a favor and get the turbo k mamber with that thing you could fit oprah through that thing
Old 03-18-2009, 03:44 PM
lifeisgood's Avatar
i have the turbo k memeber and theres a **** ton of room on both sides
tim99ws6's Avatar
I am running stock K-member. I went to a motor plate and have tons of room to run down the passenger side if i need to. I plan on running mine out the passenger side fender in front of the tire though.
Old 03-18-2009, 09:55 PM
bgblockelcamino's Avatar
it was 3 inch through pass side. snaked it between the manifold and steering rack.
do yourself a favor and have the alternator kit done and have belt ran. i screwed up once and made the DP run through belt
so just some things that get over looked when building it. BUy the real Turbo K member. someone bought a tubular k member since it was cheap. ended up couldn't fit bigger than 3 inch in there also.
i used a sphon k member with solid mounts and got 4 inch through no problem
Old 03-18-2009, 10:37 PM
For my current build I dont think Ill need anything bigger than a 3" dp...Im only looking to make 500-550hp for now
Old 03-18-2009, 10:45 PM
3 inch typically good to 500 hp. been a rule of thumb i have used
4 inch is almost equivalent to dual 3 inch
Old 03-18-2009, 11:19 PM
Sandmann120's Avatar
Ah, just dump it in front of the K-member. Go as big as you want then....
Old 03-18-2009, 11:48 PM
Turbo LS1 SS's Avatar
4" over a PA racing K with poly mounts. (cough* move the steering rack mount *cough)
Old 03-19-2009, 01:28 AM
Denali08's Avatar
That's very nice looking setup!
What alt bracket is that? and What crank pulley are you using?
Old 03-19-2009, 09:31 AM
Hmmm +1
Old 03-24-2009, 11:50 AM
dreamls1's Avatar
Here is mine, 3" tight fit but it works
Old 03-26-2009, 10:00 AM
the alt bracket is just the stock one rotated around. you'll need to support the alt from the back to the head to keep it stable as well. balancer is a powerbond
Old 03-26-2009, 10:55 AM
jfg455's Avatar
There is a regular ton, a metric ton, and now a **** ton which I am assuing is heavier than a metric ton!
Old 06-18-2009, 08:27 PM
Vetal's Avatar
Can you fit 3.5" downpipe with stock K-member?
Quick Reply: Downpipe w/ Truck Manifolds
