A2W intercooler STS question
It's possible, because you could put the IC in the trunk even which let's you size the unit pretty much however you want, but the heat exchanger (W2A radiator) would work best in the airflow offered at the front of the car. Maybe you could do it with a couple smaller radiators and fans. Having it at the front wouldn't be hard - the lines don't need to be super big, maybe -8 or 1/2".
Jim
Jim
hmmm that would be good and could run the lines with the oil return lines for the kit. what would be a good size to get? I want to try to make the sts a twin cause i have a true dual exhaust set up, do you think 2 67's would work? or should i go with bigger ones just for future endeavors?
there was a copmpany on the Vette forum that was running dual 61s and amining for 1200bhp i think. you have to get the size of the housings right! however it would be really nice to see someone use the quick spool valves like Zombie has on a twin turbo setup.
Also i hear twin GT35rs work pretty well, they lag a bit though.
could you not mount the A2W coolier in the same location as the twin intercoolers on the procharger setups? then you could still mount the heat exchange in front of the rad (make it as big as you can).
OR you could stick the engines erad in the trunk and run a MASSIVE A2A unit up front! this has been done on other cars alot. the sweedish are verygood at it lol! also a guy has done this with his C4 vette.....
Chris.
Chris.
Chris.
Chris.
