is this a realistic goal with a p-1 procharger?
Old 03-27-2009, 02:38 PM
WALK NASTY984's Avatar
Default is this a realistic goal with a p-1 procharger?
just recently purchased a p-1 procharger and plan on adding EPP blower cam....just wondering if it is possible to make 500rwhp/500rwtq....im defintelly new to the forced induction scence so please be easy on the smart *** remarks if im way off lol.......02 T/A M6 current mods are Pacesetter LT, slp lid, tsp ory.....any comments would be appreciated
Old 03-27-2009, 02:46 PM
TNTramair's Avatar
p1 should be good for more than 500rwhp....you should be fine.
Old 03-27-2009, 02:52 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Yep thats cake. I made 632rwhp with my old P1SC setup at 14psi with stock truck heads, speed inc SC2 cam, and MAC midlength headers/ Y-pipe. I wouldnt reccomend that much power for a stock shortblock tho. That was on my forged 347. On my stock engine, I made 489rwhp at 7# on my P1 with stock cam and heads and midlength headers.
Mr.Big's Avatar
my little P1 is good to 786rwhp, so you'll have zero problems...
Old 03-27-2009, 09:14 PM
what would i have to do to up the boost to around 12-14psi
Old 03-28-2009, 01:41 PM
BLNLS1/RX7's Avatar
Contact Bob at Exotic Performance Plus and he will have everything you need.
Old 03-28-2009, 02:51 PM
badass99ss's Avatar
From my experience, I would say yes.
Troy
Old 03-28-2009, 04:24 PM
EPP
EPP's Avatar
Thumbs up
Thanks! I don't recommend more than 8 psi on a stock bottom end. To shoot for 12-14 psi I would add better rods and pistons, and ARP head studs. Check out this engine build using the stock crankshaft. http://www.exoticperformanceplus.com...php?service=83 Bob
Old 03-28-2009, 06:05 PM
Customizing Director
MadIceV8's Avatar
500rwhp is TOO easy. With the cam it will throw you closer to 550 with around 7-8lbs. But with the stock bottom you want to keep it under 8lbs and 550rwhp anyways.
Old 03-28-2009, 07:11 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
500 rwhp all day long. Its the supporting cast that will cost you thousands. Items like trans, diff, blown engines, tires, brakes, etc.
Old 03-28-2009, 08:12 PM
DarkFormula's Avatar
Ummm, 13psi here for five years on a stock bottom end revving to 7k RPMs. It can be done.
