cant decide eather a 78 or 88??
Old 03-27-2009, 08:56 PM
Taubr Unit's Avatar
Default cant decide eather a 78 or 88??
Im on the fence right now to buy a kit but inbetween on what to buy. Right now its a stock longblock 6.0 with valvetrain, vic jr intake and 60lb injectors. Later on down the road ill eventually build the motor but still nothing CRAZY, just a simple forged 408. Been talking to Josh@Kentucky but i cant decide what route to go. Id like to do the t6/88 kit but the t4/78 is about $1500 cheaper so thats a BIG plus. Just wondering how far i can take the t4/78 or just do the t6/88 now and have it done for a better motor.
Old 03-27-2009, 09:10 PM
Grr
Grr's Avatar
go to the classifieds or racing junk and pick up a GT47-88 for about $1400, problem solved. The 78 is a great turbo and all, but what the hell, i would want a 47-88 on a 408 motor, the 78 would be pretty small and would spool so fast it would be hard to hook anyway
Old 03-27-2009, 09:14 PM
theblur98ss's Avatar
What is the rest of your fuel systems. 60's aren't gonna support the 88. I'd go for the 88 if that's where you hope to end up anyhow. Do it once....do it right.
Old 03-27-2009, 09:16 PM
Taubr Unit's Avatar
i have a sumped tank, a1000 pump etc. so im good in that area
Old 03-27-2009, 09:17 PM
VENGEANCE's Avatar
Old 03-27-2009, 09:42 PM
dudeman's Avatar
"they" say the 78 is good for 9's and 140+trap speeds.
Old 03-27-2009, 10:06 PM
VENGEANCE's Avatar
well a 76 is good for that easy on a supra......
"they" will also say it doesnt work that way on an LSx.
Old 03-27-2009, 10:09 PM
ItsNotStock's Avatar
I was spec'd an 88 by Jose. Look at the people running 88's on this forum, veee8, Mighty Mouse and many others... enough said
Old 03-27-2009, 10:12 PM
Taubr Unit's Avatar
now is there a big difference between a t6/88 and a t4/88?
Old 03-27-2009, 10:13 PM
dudeman's Avatar
https://ls1tech.com/forums/forced-in...78-limits.html
Old 03-28-2009, 12:02 AM
You're right. I believe Mighty Mouse had the PT88, and vee8 had the Gt47-88 with was a T6 turbo instead of the T4 the PT88 is. I will most likely never come close to pushing the stated 1250 limit. To me that's pushing the limit between a streetable car, and a full on drag car. And if your aim is 85%+ track then from what it seems most people step up to larger turbos.
Old 03-28-2009, 12:11 AM
94dragbird's Avatar
Wont the PT88 spool faster since it has the smaller T4 housing compared to the bigger T6 housing of the GT47-88?
Old 03-28-2009, 09:55 AM
LS1TECH Sponsor
DrTurbo's Avatar
No...spool will be the same. Also you can go with the GT88 from Garrett which is the mid-frame version of the GT47-88 and its only 1250 bucks!!
Old 03-28-2009, 10:09 AM
94dragbird's Avatar
So the GT88 is more comparable to precision's PT88?
Old 03-28-2009, 01:23 PM
B18CYA's Avatar
400+CI=T6.. A tc78 will make as much if not more power on a 346-364 without all the back presure
Old 03-28-2009, 04:42 PM
b00sted's Avatar
I know of a similar weight(maybe a little heavier), similar cube car(less than 350ci actually) that went mid-low 9s with a 78. That was with a loose converter and no boost controller. Only 21 psi(as opposed to the 30ish he wanted to run).
78 is perfect for your goals, and would be more fun on the street.
Old 03-28-2009, 05:41 PM
Restricted User
98Z28CobraKiller's Avatar
And here I was debating as to whether I should have bought my PT88 or held out for a deal on something bigger. I figured that since my turbo came off a V6 GN, it had to be too small.
Quick Reply: cant decide eather a 78 or 88??
