Turbo LS1 GTO 517whp & 53X trq on 8psi
Old 03-28-2009, 07:52 PM
02Vortech's Avatar
Default Turbo LS1 GTO 517whp & 53X trq on 8psi
Buddies LS1 GTO with STS kit just some new numbers.
DynoDynamics dyno
Car Specs:
2004 GTO LS1 6-speed
STS kit with Turbonetics GT67 @ 8psi
Snow performance stage 2 meth kit
Ported TB
Textrilla Clutch
39lbs injectors
No FMIC
517whp & 53X trq.
on 5.5psi car put down 445whp don't remember the torque and that was without a ported TB.
Will post dyno sheets as soon as he gets them.
Old 03-28-2009, 08:04 PM
Y2K WS6's Avatar
bad ***! love them GTO's i'd own one if they had a bigger trunk or a topless feature!
Old 03-28-2009, 08:31 PM
02Vortech's Avatar
I am seriously considering one right now. Great car, and the interior is worth ALOT IMO.
Old 03-28-2009, 10:14 PM
Texas Heat's Avatar
Not too bad! Mine with stock LS2 and the 70mm made 630rwhp. How much is the difference between a dynojet and a dynodynamic dyno?
Old 03-29-2009, 10:23 AM
geeteego's Avatar
Nice!
Good to see more GTO rear-mounts making some power.
Old 03-29-2009, 10:28 AM
04pontiacgto's Avatar
how does it drive? I have debated picking up a STS kits up, just wondering about "lag". STS told me there would barely be a difference between a front and rear mount kit, but before I did anything I wanted to hear what others had to say.
Old 03-29-2009, 10:36 AM
JAX04's Avatar
this is great for me to know. as i am currently building a t70 turbo setup on my 2004 ls1 gto. a4. this makes me very happy cuz 500whp is what i was going for. im using 60lb injectors though. and a walbro 255 and a BAP
Old 03-29-2009, 11:26 AM
99Z28LS1's Avatar
the STS kit is known to have lag simply because of the placement of the turbo. you can combat the lag if you have an automatic, wrapped y pipe and stock manifolds. 6 speeds can get boost pretty quick, but nothing like the automatics can
front mounts will always spool faster
Old 03-29-2009, 02:34 PM
02Vortech's Avatar
he also has test pipes on the car and the exhaust is not wrapped.
the lag is really minimal and the car pulls really hard
Quick Reply: Turbo LS1 GTO 517whp & 53X trq on 8psi
