Turn up the boost or upgrade the turbo ?
Old 03-29-2009, 03:13 PM
oakfan52's Avatar
Default Turn up the boost or upgrade the turbo ?
I have an STS 06 GTO with the base 60-1 turbo. I made 422HP/432TQ @ 5psi. I wondering if I should turn the boost up and get it re-tuned or if I'm just wasting my time with this turbo. I would like to get to 500 rwhp. I have a meth kit running 50/50 mix.
Old 03-29-2009, 04:06 PM
thobart's Avatar
Default That turbo is
good up to about 10-15 lbs. Should make about 25hp per pound to the ground and spools really fast. I would say keep it and turn up the boost as long as you have the supporting mods to make it safe!
Old 03-29-2009, 09:23 PM
Johnv's Avatar
suck it and see !
Pretty easy to add a boost controller and wind it up to 10-12 psi as long as you have plenty of injector and fuel pump left.
I'd prob go 100% meth though.
Old 03-29-2009, 10:36 PM
oakfan52's Avatar
Ya. I'm trying to figure out if its worth it to pay $500 for a re-tune to turn the boost up just fins out it only adds 25rwhp. Then I have to get a larger turbo and pay for another tune.
Old 03-29-2009, 10:43 PM
99Z28LS1's Avatar
that's ridiculous! There shouldn't be any kind of charge for another "small" tune
Old 03-30-2009, 12:41 AM
oakfan52's Avatar
Well I had it done at a different shop that is now gone.
Old 03-30-2009, 07:17 AM
WarShrike's Avatar
Still, $500? Is this a dyno tune or just strictly a reflash?
Old 03-30-2009, 12:42 PM
ScorpionT's Avatar
Turn up the boost! $500 seems a bit much, most guys would charge $100-150 base and maybe an hour of dyno time.
Old 03-30-2009, 12:45 PM
Louis's Avatar
It all depends on who is tuning it! That PCM isnt like the 99-04 cars, where its cake to throw a 3 bar at it and crank the boost up at will....
Old 03-30-2009, 01:04 PM
Jimmy P's Avatar
It it has already been tuned for FI, then paying an extra $500 for someone to look at the A/F and timing because of more boost does seem like a bit much..
Old 03-30-2009, 01:08 PM
TARZAN's Avatar
Bump it to 8-10 lbs. and get a retune.
-Will
Old 03-30-2009, 03:11 PM
Blades's Avatar
As long as you have the 2.5bar OS, the cmd AFR will be boost based. The boost VE will need to be verified and the spark table will obviously need to be adjusted. @ 5.8lbs you may not be reaching the end of the table.. so if the values at the end are tapered down enough, you'd have the reduced timing that you need for the increase in boost.. However, if the AFR Spark Correction table is not well adjusted, the increase in commanded EQ ratio may end up adding more timing than you can safely run.
At $500, you could (and should) purchase HPT.. Please do this. We obviously can help with such a small change.. What you'd need is a Wbo2 with the analog signal sent to the HPT interface, properly calibrated for ground offsets (I can help). Then.. a couple dyno pulls.
Do not use a boost controller.. They are crap crap crap. I could not get a turbosmart MBC to work with my setup and the EBCs are very expensive. WG springs are cheap and very easy to install.. If you are hell bent on getting a MBC, you might as well take a thick needle and start poking holes in your vac line to the turbo - as this is equiv to what a MBC would do (don't do that, just making a point)
Old 03-30-2009, 08:51 PM
OUTLAWZ RACING's Avatar
Wtf get rid of that tiny turbo
Old 03-30-2009, 10:16 PM
longrange4u's Avatar
You are in an LS2 car?? You should have never gone with that 60-1 (Not bashing you bro).... Upgrade to a 72mm or so... Spend the extra 500-1000$ and get a FMIC... retune and you will see ~600RWHP at 8-9psi.
I say 634RWHP on a 346 Stock LS1 with FMIC and 72cc stock truck heads. Safely ran it at 580RWHP... With an LS2 you could see 600-625 safely (In my opinion) with just what I mentioned above.
Old 03-31-2009, 05:35 AM
Blades's Avatar
If it makes the boost, holds the boost, and does not produce excessive IATs... what would be the point? In my case, I probably do need a larger turbo.. but not yet.. The TBSS A4 (built up twice) would have a hissy fit on me and then die for a third time.
Old 03-31-2009, 08:19 AM
Yeah it makes and hold boost but back pressure is going to go up and iat are going to go up when you push that turbo harder. like the above post bro upgrade and love it.
Old 03-31-2009, 08:32 AM
TARZAN's Avatar
Guys, you're all giving great advice....but all he said he wanted was 500 RWHP....he never said anything about looking for 600+ or anything.
-Will
Old 03-31-2009, 12:11 PM
lt170chevelle's Avatar
i SAY GET A WIDEBAND AND TURN UP THE BOOST ..IF IT NEEDS MORE FUEL THEN GET IT RETUNED
Old 03-31-2009, 11:43 PM
Blades's Avatar
Good point about the back pressure.. Would this be because of the turbine difference or mainly because of a larger downpipe? Regarding the IATs and pushing the turbo harder.. is this in part to increased oil temps? I have added an oil cooler. One seems to be the cause of another and vice versa.... Pushing the turbo harder = increased oil temps = pushing the turbo even harder than before. heh.. ?
I'll have to collect a bunch of datalogs and see what the relation to oil temp vs ambient temp vs intake air temp vs boost vs boost duration. Heh, thats a lot of stuff to compare, but you get the idea. I think the duration (of the boost) is my IAT heater.. makes sense. Like an overdriven M112 Eaton...
What fluctuations in IAT do you see @ a given boost level.
Old 04-01-2009, 08:46 AM
-Will
Yeah that turbo is good for it but on a 346 not a 364.
Quick Reply: Turn up the boost or upgrade the turbo ?
