What rpm do you spray meth at?
You want it to come on according to boost... I use a Honeywell Heavy Duty Hobbs switch. I used to use the one that came with my Snow kit but it looked like a POS.... so I rather put my trust in a better switch.
Mine comes on at 2-3psi and stays on until I let off. Works great.
I actually put together a kit for my car a few years ago for only about $60. Of course it isn't nearly as nice as the ones mentioned above, but it did work. I used a 10psi pressure activated switch that I got from NOS to kick on an industrial rated chemical pump and sprayed into the intake using a dry style nitrous jet and nozzle.
I hope this helps,
-John
I hope this helps,
-John
With my Alkycontrol kit i set it to turn on at .75 psi and max at 15psi. reason im running it that low i have 11.1 compression on pump 93 with a F1C and i get good intake cooling by about 3-4 psi and max cooling by 9 psi
The main goal of meth injection is to suppress knock so if your not knocking at 3000 rpm and have all the timing you need then your good with out it
But if your looking for more power crank the boost up or add timing But spray before you have knocking. So if it close to knocking at 5 psi spray at 2-3 psi for a safety net
you can always add power adders and what not with out tuning. IT may or may not hurt your car, depends how much you push and use it. I mean what's your car worth to you? If you don't care then do what ever. Personally I would tune after I add anything to my car. I don't have a good ear to hear things, so I'd rather play safe, drive my car longer and have fun longer, as opposed to break something then build new.
I'm not an expert in Meth, but the basic principle the way I understand it is that it cools your air intake and will make you have cooler air, so you can have more hp due to the cooler air. It probably won't hurt one bit to add it and spray it. It sounds like it's there to prevent knocking. Knocking is bad, so if your knocking and you spray then that's good.
I'm sure someone will chime in there, but personally I'd tune it.
