D1SC with 3.2 pulley, what boost at 3000 rpm and 4000 rpm?
Old 03-31-2009, 11:38 PM
MikeC5Vert's Avatar
Default D1SC with 3.2 pulley, what boost at 3000 rpm and 4000 rpm?
Hi,
I got D1SC with LQ9 6.0L heads, 224/228 581/588 114 lsa cam, and 4.10 gear.
What boost at 3000 rpm and 4000 rpm since those are the range I cruising around town?
Thanks so much in advance!
-Mike
Old 03-31-2009, 11:42 PM
Avengeance's Avatar
Which balancer are you running? Also... at cruising it wont be making any boost. Its really hard to tell what boost youll make.
Old 04-01-2009, 12:22 PM
T/A KID's Avatar
I don't know if this will help, but I have a 7.65 crank and a 3.2 BP on my LTX setup and I start making boost at 2400rpms.
Judging by that I am spinning the blower at 23.5 thousand rpms. So I am assume thats when a D1SC starts making boost, or on my setup anyways.
Old 04-01-2009, 02:57 PM
MikeC5Vert's Avatar
I got a C5 vette with stock balancer. I understand that cruising will not making any boost but I meant when I change gear and step on the gas pedal to go around 3000 - 4000 rpm ... what kind of boost I'm seeing ?
-Mike
Old 04-01-2009, 02:58 PM
MikeC5Vert's Avatar
That is great to hear that it start making boost at 2400 rpms.
Thanks!
-Mike
Old 04-01-2009, 09:53 PM
9sectruck's Avatar
if your belt is not slipping at all (6rib?)I would say u should be making around 5-7 at wot going into the 4000 rpm on bone stock heads
Old 04-01-2009, 11:49 PM
Jimmy P's Avatar
That blower pulley should max out the D1SC.
Old 04-01-2009, 11:52 PM
MikeC5Vert's Avatar
Hi, what do you mean by max out?
Thanks,
-Mike
Old 04-02-2009, 12:37 AM
JMBLOWNWS6's Avatar
He means you will spin the blower to its full capacity.
Old 04-02-2009, 01:13 PM
T/A KID's Avatar
The D1SC can be "Safely" spinned to 62,000rpms. With my combo it maxes out the D1SC at an early 6300rpms, I rev to 6200.
Old 04-02-2009, 07:43 PM
firehawk123's Avatar
Is the Cubic make any diffrent with boost .. if the have supercharger D1SC with 350ci and its making 10 PSI and i change to 408ci it should make more boost or less boost or the same boost if am using the same pullys .
Old 04-03-2009, 05:10 AM
EPP
EPP's Avatar
The boost will go down, Jassim. The reason is you have more volume to fill. Bob
Old 04-03-2009, 05:14 AM
EPP
EPP's Avatar
Originally Posted by MikeC5Vert
Hi,
-Mike
Mike, there are so many variables which make it really hard to predict how much boost you will make at any given rpm.
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a D-1SC.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost. Bob
Old 04-03-2009, 09:21 AM
MikeC5Vert's Avatar
Thanks so much guys!!!
-Mike
Old 04-03-2009, 10:01 AM
Thanks bob . its really good info .
Old 04-03-2009, 10:47 AM
EPP
EPP's Avatar
You're welcome! Bob
Old 04-03-2009, 05:04 PM
Mark98SS's Avatar
I have an opportunity to pick up a 418 9:1 motor, will that be too big for my D1SC? If I can get it to run as well or a little stronger as my cam only 346 did at 7psi I'll be happy.
Old 04-03-2009, 07:12 PM
T/A KID's Avatar
Go for it that will work great with a D1SC. Remember that blower is rated at 925hp/1400cfm. You'll most likely make less boost on the Bigger ci motor but thats just because its more efficent.
I'd take a motor that made 10lbs=700hp, then one that did 20lbs=700hp.
Old 04-04-2009, 01:41 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Please explain this reasoning.
Old 04-04-2009, 07:25 AM
EPP
EPP's Avatar
No, not at all, check this build out.
http://www.exoticperformanceplus.com...Car.php?car=42 Bob
Quick Reply: D1SC with 3.2 pulley, what boost at 3000 rpm and 4000 rpm?
