A&A Corvette blower cams?
How many of you are running any of A&A Corvette's blower cams?
They make alot of choices from small to big. For a 8-9 # D1SC kit on a
stock bottom end LS1 with either stock 241's or mildly ported LS2 or 241 heads and headers and catback. I have a A4 and plan on getting a Vig.3200 stall and the A&A cam i'm looking at is either their Stage II or Stage III cam. Anyone that runs these cams please post how you like them and what power you made, and if you have track results please post them. Heres the specs on each cam.
Stage 2: 214/228 .559/.571 117lsa
Stage 3: 218/232 .563/.575 117lsa
I'm still looking into the GT2-3 cam since there's guys running 10's and even 9's with it. But i'm hoping to have alittle lope sound thru the exhaust.
Another though i had would be to just install a nice n/a cam like the AFR 224/228 114lsa cam as well. It seems to me that the D1SC blower works great even on strong n/a cams as well. If thats the case the Predator-Z cam that he spec'd for me might work great and that was a 218/224 .604/.609 113lsa +2 on Comps XE-R lobe. And have my stock 241's ported so they flow around 280cfm at .600 lift and try to keep the compression as close to stock as possible and use a slightly thicker head gasket and install ARP studs. But i'm trying to get some info. from guys running the A&A cams to help me to make
an informed decision. Thanks.
