turbo manifolds.
turbo manifolds.
ok guys I finaly got my LQ9 built and dropped into my 240sx. Now I am going turbo, but the truck mani's dont clear the frame and body work, are there a slimmer type of gm manifold I can use? Open to suggestions.
waiting for the c6 manis to come in, I will find out if they will fit. I have an s13 240sx im going to have to see if I can stick the turbo there too. I was going to put it on the pass side near the battery and just move the battery to the trunk. I dont have enough room to run a 4 inch downpipe on the drivers side. what size dp does that s14 have?
if the flange is interfering with the frame cut them off and tig weld 2.5 stainless v band clamps on. Make sure you preheat it to 250 to 300 deg. the use silicone bronze rod or 308 rod. After you are finished wrap the welded area with a fiberglass wrap and let it slow cool for about 2 hours. Hope this helps. Mike Salkowski
where exactly dont the mani's clear? do you have any pics of the clearance?
