trick flow heads vs afr/edlebrocks by west coast cylinder
Old 04-07-2009, 11:24 PM
LM7 Sportside Z71's Avatar
Default trick flow heads vs afr/edlebrocks by west coast cylinder
Boosting a 370 cubic inch 6.0 iron block looking to make decent numbers like 700-900 at the wheels and thinkin i should go with aftermarket casting for the thicker deck surface(dont wanna push water) i was told these three being some of the best. wondering if anyone has any experience or preference with any of these three? any help would be greatly appreciated!
Old 04-08-2009, 12:51 AM
tomz28's Avatar
i have a friend that used 225 trickflows out of the box on a LS2 364ci built motor on 28psi and it made over 1200wheel but he pushed water at 20psi or so.
for 900wheel no matter what you get you should be fine. the trickflows need longer push rods a roller rockers to use them. afrs do not but trick's have better mid-lift flow
so its a win win no matter what you do
Old 04-08-2009, 02:18 AM
BigRich954RR's Avatar
For 700-800hp Id save the money and get PRC CNC head for 900hp and up aftermarket deck is worth it Id would look into the trickflows very nice head. Right now im stuck between PRC aftermarket casting head and the trickflows only cause i need a 6bolt head.
turbo or supercharger?
Old 04-08-2009, 12:53 PM
mine will be turbocharged im think aps twin kit. so he still pushed water at 20 psi? hmm well idk and u said i need longer pushrods and roller rockers to run trickflow heads?
Old 04-08-2009, 01:08 PM
crf538's Avatar
remeber pushing water is a function of pressure and therefore timing and fuel...its not only intake pressure that will cause it. Im pretty sure there have been people that run 20 pounds on stock castings and dont push water. im not saying dont run thick decks, just that its impossible to say X head will push water at a given boost level.
Old 04-08-2009, 02:37 PM
pushing water has lot to do with other things then boost ive seen people run 24psi on stockcasting head that were just ported by PRC.
A heavy car or alot of boost early in the rpm range rises psi up alot and might push water.
Because it a turbo car i would lean to aftermarket casting
Old 04-08-2009, 10:03 PM
yea for sure i know timing has a lot to do with it, im going with 225 trickflows, i figure i might as well spend the extra money and try and prevent pushin water with atleast the thicker deck surface. thanks for the advice!
Old 04-09-2009, 12:00 AM
tomz28's Avatar
on my buddys motor 20psi= alot of power
i know that boost dosent lift heads but cyl. PSI
but i think AFRs have a thicker deck by .200 i could be wrong
Old 04-09-2009, 12:53 AM
TT-TECH Veteran
Inspector12's Avatar
I've used all the above I prefer the TFS. GL! They will all make power for sure.
Old 04-09-2009, 01:10 AM
tomz28's Avatar
inspector i go with you man you seem to be doing something right with two badass cars LOL
Old 04-09-2009, 09:09 AM
for sure inspector what turbo kit did u use on the car with the 402? very badass cars that make solid numbers!
Old 04-09-2009, 10:42 AM
TT-TECH Veteran
Its one of the Speed inc. street twins they used to make before APS came out with DDBB 67's. I still have AFR's on the black car and they are nice so don't get me wrong its preference when this stuff comes into play really heads aren't as important in FI as when you are talking N/A, but if they make more power N/A then in theory they should make more power or the same at a lower boost level. And all the great N/A combo's I've been putting together for people have been using theTFS heads. I don't think you can beat them with out spending considerably more money etc...
Old 04-13-2009, 12:39 AM
if possible i would be curious to see a build sheet on what supporting mods like fuel, heads, cam, turbo size, intake etc. and what ya made them numbers at and on what psi? just to give me a idea maybe of what i can make on 93 octane...
Old 04-13-2009, 06:43 AM
Firechikn's Avatar
I'm using the edelbrock from WCCH. I've had no problem with them. Fast shipping too. I've run up to 18psi ( 900-950 range ) and never pushed water. I should be turning it up a little higher soon.
Old 04-13-2009, 08:33 AM
Johny GTO's Avatar
dont the edelbrock heads have the thickest deck around?
Old 04-13-2009, 10:52 AM
TT-TECH Veteran
Well like I said in the earlier post they are DD BB precision 67's with P-trim exhaust housings, Twin walbro's intank #8 feed, using stock as the return, That was an old cam I had designed to be used with a S/C but the deal I had with a person fell through and then I bought the turbos from Jim at Speed Inc.The cam was 236/240 on a114+4 low 600's lift on XER's and that was on 15# of boost and it was also at 4800rpm's as it would start floating the valves after that, if it would have carried it would have been considerably more I believe but haven't been back since the heads and cam change I am guessing it is in the same range currently etc... Its a LS2 based 402 Lunati crank, Howard rods and Mahle pistons with TFS 235's although at the time of the dyno I had the TFS 225's on there with LS6 intake on 93 octane
Old 04-13-2009, 11:12 PM
ic yea them seem like pretty damn good numbers. i was going to go with a 402 but texas speed said to stick with the stock stroke for boost. they also did the cam specs... so i have 370, stock crank, 6.0 iron block, diamond pistons, eagle rods, ls2 intake, trickflow 225's 92 mm tb, 80lb injectors, lonnies performance fuel pump good for 1000 plus, my cam is 114+2 i believe and its 228/234 581/598 and im thinkin ill prob run the twin aps intercooled kit on 93 octane, run alchy later maybe. compression should be right around 9.2-1 with my piston/head/gasket combo have ne predictions what i should roughly make on 93 octane through a 6speed car with a good amount of boost?
Old 04-14-2009, 01:21 AM
TT-TECH Veteran
Yeah I had the Lonnies dual set up in my black car and well I have a different opinion after going in and re-doing it lol! Hope it works for you! GL!
Old 04-14-2009, 07:02 AM
Frost's Avatar
If all of your concern is around pushing water and you have the budget, just drop the 4-bolt platform all together.
Quick Reply: trick flow heads vs afr/edlebrocks by west coast cylinder
