bypass valve location
I was told to put it before the intercoolers so the only time hot air was going through them is when you want it in the engine. No heat soak of the cooler. Are you going with the twin or a front mount intercooler?
http://mycarpics.shutterfly.com/235
http://mycarpics.shutterfly.com/219
http://mycarpics.shutterfly.com/226
-Scott.
Nicely done BTW
BlkHwk,
Maybe you could run a hose from the outlet of the BPV and position it so it wouldn't blow a bunch of crap under the car.
I just wouldn't want to push any more hot air through an intercooler than necessary.
-Scott
-Scott
Thanks man. I had my bypass facing the gound and it did make a dust mess so I just rotated it on the flange so it points up to the washer fluid tank, no more dust cloud. Also from what SDCE told me when I bought the kit the smaller twin intercoolers are the worst for the heat soak compaired to the large front mount. When I switch to a front mount I still will try to mount the bypass before the cooler.
